new Clutch
 Post subject: new Clutch
Posted: Mon Sep 10, 2007 3:32 pm
Ride: EL FAIRMONT GHIA 97
i wouldnt mind getting a new cutch for the falcon, as i will be doing a conversion, what would someone reccomend and from where?
-------EL Fairmont Ghia with CUstome BA XR body kit-------
Posted: Mon Sep 10, 2007 7:34 pm
Ride: FGX G6ET
I just replaced mine with a heavy duty Valeo one from eBay (http://stores.ebay.com.au/Sunbury-Brake ... ore-Clutch). Cost me $235
Some people might recommend some fancy organic type s**t or something...I really don't see the point on using anything other than "standard" on a family car...unless you have some decent engine mods.
Posted: Mon Sep 10, 2007 7:40 pm
Ride: ef 5 speed
i would use an el xr6 clutch they dont brake the firewall welds
i am in need of a new front bar or good condation secondhand for a 95 ef futra,
lsd for a for ef ,modifed au sump to go in and ef , working air con compressor
Posted: Mon Sep 10, 2007 8:11 pm
Ride: FGX G6ET
EL XR6 did come with heavy duty clutches...hence why I used one in my XR6...and don't buy from Ford.
Posted: Mon Sep 10, 2007 8:30 pm
Gallery: 5 images
Ride: 2021 Amarok V6
u sure about that? my standard EA clutch snapped the firewall in 3 places :shock: its getting fixed tomorrow haha
Posted: Mon Sep 10, 2007 8:43 pm
Ride: 93 ED sedan
Power: 161 rwkw
I have a PBR RPM Clutch in my EA. It has never had the firewall crack, or the pedal box destroyed. I have simply rerouted the cable to make it smoother.
http://youtu.be/jJTh9F3Vgg0
Posted: Tue Sep 11, 2007 12:56 pm
whats this about the firewall cracking??
how does changing the clutch in the box affect the firewall.?
Posted: Tue Sep 11, 2007 11:03 pm
Ride: 93 ED sedan
Power: 161 rwkw
If the clutch isn't adjusted properly, the firewall or pedal box can be damaged.
Posted: Wed Sep 12, 2007 10:58 pm
Gallery: 21 images
mabee give mal wood automotive a call.
bf xr6turbo siemens injectors, full plazmaman 800 hp intercooler kit, 5 inch cat and custom dual 2.5 inch zorst, billet flywheel with mal wood clutch kit, braided hoses, big brakes, 3.2L surge tank/w twin 044's rebuilt motor with forged and billet everything 420+ rwkw on 98. holden killer.
Posted: Thu Sep 13, 2007 11:17 pm
WELL... i replaced my clutch 3 weeks ago(standard valeo- I told him I give it to it occasionly, he said it would be fine)-along with input shaft, week later slipped, took back had new pedal box put in and firewall welded , 2 weeks later slipped!!! Took back in, the mechanic put new clutch(same as above) now slipping again!!!!!! $1,350 all up dammit!!!
He now tells me( "eb's dont go like this, it pumps put more torque then normal you need a HD unit") (prolly coz no cat extrac's, 2.5 all way through, and a good ol 5 speed)
I took him for a drive and the clutch slips at around 2,500rpm-3,000rpm-but get this, if you put your foot under the clutch pedal and lift it up it stops slipping!!(yes I put new cable in---TWICE )
i THINK HE EXPECTS ME TO PAY FOR A H/DSPRING/PLATE UNIT)
H E L P ! !
he also tells me that he would expect his EL2 XR8 UTE(5SPEED) To slip if he took it to 5, 000rpm- thats not normal!!! right??
I beleive my inline 6 should be able to be taken to redline occasionly, i mean lets face it , it would be f**k if I done it all the time to a relativly standard motor!!
But I think a standard duty should do me but obviously not any n :cry: sugesstions?
EF Ghia 5L V8
BAMk2 XR8 Velocity/Cobra 19's
Posted: Thu Sep 13, 2007 11:37 pm
Gallery: 13 images
Ride: EF
somthing else MUST be wrong, as with the mods youve got you shouldnt be, rooting a new stock clutch in 2 weeks, unless you cant drive :P
was your flywheel mechined?
and the clutchfork not bent?
latest mod: A Service
Posted: Thu Sep 13, 2007 11:39 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
typical for the firewall.
Lifting the pedal shouldn't have any affect on the clutch at all.. theres not enough force applied to the fork to do it any favors.
I don't get any slip in my stock standard PBR replacement XR 'spec' clutch.
Perhaps the yolk the thrust bearing slides on is worn preventing it from returning to a load-less stationary position.
Posted: Sat Sep 15, 2007 11:00 pm
Ride: 93 ED sedan
Power: 161 rwkw
How is the rubber bush in the end of the clutch fork????
 Post subject: Clutch even got mechanic buffed!!!!!
Posted: Sun Sep 16, 2007 9:14 am
The bloody thing stops slipping when I lift the pedal up with my foot!!! eg: put under the clutch pedal when slips and lift up 1-1.5 inches!!!
I dont know how, or why this happens it just does
2x new clutches
1x new pedal box
1Xnew input shaft (nose cone??)
firewall welded
2X new clutch cables
i am getting really, really REALLY frustrated with my trusty wagon!!!!!
mechanic cannot work out prob! :idea:
EF Ghia 5L V8
Posted: Sun Sep 16, 2007 9:34 am
Ride: 1989 300ZX Twin turbo Z32
your clutch probly isnt adjusted properly and the clutch is partially disengaged when your normally driving. and when u pull the pedal up it allows the clutch to properly engage
btw you should be taking the clutch really easy for the first 1000kms
Sold my EB :(
Now got my 300zx :)
Users browsing this forum: Google [Bot] and 23 guests
It is currently Sun May 18, 2025 3:27 am All times are UTC + 11 hours
