JETXR6 |
hi guys i have a heavy thumping sound from the front drivers side wheel, especially when turning???
Paulmac |
Check your wheel nuts, if they're tight place your hands on top of the tyre and try to rock it in and out. If the wheel moves/clunks it is probably your wheel bearings. It could also be a ball joint or disintegrated bush. Only a thorough inspection, which should be done ASAP, may tell for sure. As for example, a failed wheel bearing may be caused by any of the others and vice versa. The longer it carries on the greater the danger.
Paul
_________________ What goes around, comes around. |
