20's on an eb
Page 1 of 1 [ 15 posts ]
 Post subject: 20's on an eb
Posted: Fri Jan 04, 2008 2:21 pm
Ride: AU XR6
Power: 171 rwkw
I've recently purchased a set of 20's to share between my au and eb and am having some difficulty with the fronts on the eb. Theyjust clear the inside of the guard which is nice but just touch(only just) the top control arm on the inside. at first i thought id just get wider spacers but with the proximity to the guard this isnt feasable. A mate told me to get the grinder out and remove the offending area of metal, I'd probly have to shave between 1-3mm off to do the job. My question is:
Are AU control arms shorter than the eb ones, and more importantly do they fit? and is there a difference between the AU1 and AU2 ones
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG 60000km stock as, mods to come.
97 el futura about to be MOCKed
Posted: Fri Jan 04, 2008 3:09 pm
Ride: EF XR6 manual
Your mates a d**k head!!! DO NOT under any circumstances grind cut or weld your control arms. EB and au run different off sets. Your best option would have been to speak to the place that you got your wheels from & tell them your plans from the start, they may have given you a couple of ideas on how to go about it ie. 1/2" narrower wheels with a different backspacing/ offset. And i don't believe that the au arms will fit into an eb.
EF XR6 5spd 14.57@97mph
154rwkwts
Posted: Fri Jan 04, 2008 4:08 pm
Ride: AU XR6
Power: 171 rwkw
thats wat i told him he was. and i was already aware that the offsets are different hence the spacers, and the wheels only came in the one width
Posted: Fri Jan 04, 2008 4:50 pm
NSW Cruise Moderator
Gallery: 12 images
Ride: TE50
then you did not really have any other options at the time of sale if you wanted those rims, you may want to look at a SMALL space to give you the clearance on the upper control arm, and get the guard inners rolled to give you the required clearance. other than that you would need to reinvent the wheel somewhat.
I have a car.
Posted: Fri Jan 04, 2008 9:46 pm
Ride: LS3 VF
or get over the idea of putting wheels 5 or 6" bigger than standard on an EB
Posted: Fri Jan 04, 2008 10:25 pm
what he said^^^
any wheel that big is going to look stupid on an EB.
Posted: Sat Jan 05, 2008 8:16 am
Ride: AU XR6
Power: 171 rwkw
what he said^^^
oh id have to disagree with you there, the wheels look s**t hot they are envys by speedy with the gold spokes, which against the everglade green of my car looks PHAT
Posted: Sat Jan 05, 2008 9:39 am
Ride: AU2 Ute
pics?
What about changing to a narrower tyre?
Posted: Sat Jan 05, 2008 10:16 am
what he said^^^
the wheels might look good. but that size on an EB will look out of place and stupid
Posted: Sat Jan 05, 2008 12:59 pm
Ride: LS3 VF
exactly. Not to mention dangerous if the offset is wrong, and illegal.
Posted: Sat Jan 05, 2008 2:17 pm
Ride: AU XR6
Power: 171 rwkw
pics?
as soon as i get the digi camera working ill post them
Posted: Fri Jan 11, 2008 2:04 am
Jesus H christ!!!
Posted: Fri Jan 11, 2008 8:40 am
Ride: AU XR6
Power: 171 rwkw
Jesus H christ!!!
what?
Posted: Fri Jan 11, 2008 10:02 am
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
What size tyres?
And how wide are the rims?
You can take a bit off the upper arm, I had same clearance issue with a mates FR19s with 245s on them.
BF MKII F6 Tornado - 237rwkw
Posted: Fri Jan 11, 2008 11:11 am
Ride: AU XR6
Power: 171 rwkw
20x8.5 i think and 235/35s
Users browsing this forum: FGXR, Google [Bot], Google Adsense [Bot] and 25 guests
It is currently Sun May 18, 2025 8:29 pm All times are UTC + 11 hours
