Oil for gearbox and diff.
Page 1 of 2 [ 29 posts ] Go to page 1, 2  Next
 Post subject: Oil for gearbox and diff.
Posted: Thu Jan 05, 2006 9:16 am
Ride: BF XR6, BF XT Wagon
Power: 197 rwkw
Got two cars EF and EL that have manual T5 gearboxes and LSD 3.45 diffs.
I was going to put in redline oil but its too expensive. What oil is recommended to put in the gearbox and LSDs?
Posted: Thu Jan 05, 2006 10:54 am
Ride: EF Fairmont
for the boxes put normal auto-trans fluid in it. For the LSD's penrite do a lsd oil its bout ($20), dont bother with the hypoid oil, thats the oil that i got told to use with my dif after it got built. ask fras what the name of the oil is i gave him a bottle of it for that lsd he got bout 2 weeks ago.
EF XR8 - 5speed, Extractors & Exhaust
Posted: Thu Jan 05, 2006 11:11 am
Ride: AU XR8
HI
i recently had the same question about 5 speed oil...
ford recomend use dexron trans fluid.. also most members here recomend dexron aswell.. but when i talked to gearbox reconditioners they said that i should use 80/90 gear oil..as trans fluid is a thiner oil it will give you a smother gear change but will get to hot under heavy loads and will cause the fluid to burn ..
thats why the v8 t5 uses gear oil instead of auto fluid.
so if you give your gearbox a workout or do towing i recomend using gear oil..
Posted: Thu Jan 05, 2006 11:16 am
Ride: No Fords current
When I got my EF XR/Tickford diff (3/45 LSD) I went through all the manufacturers oil books (that I had lieing artound at work) to see what they recomended/said.
*Castrol SAF-XA (part number: 118975 I think) - this is the one I ended up going with!
*Mobil SHC ID
*Penzoil GPS 80W-140
*Penrite 10 Tenths Synthetic 80W-140
Valvoline SYN 75W-140
By the way, capacity of the diffs is 1.6 liters each.
And don't forget to add some Nulon G70 with it - wonderful stuff that!
Posted: Thu Jan 05, 2006 1:49 pm
penrite 10 10th 80 w 140 in the diff
castrol transmax-Z in the T5
Posted: Thu Jan 05, 2006 2:17 pm
what he said!! ^^^^
penrite limslip diff oil it is blue and the s**t!
RIP SCOTT
Posted: Thu Jan 05, 2006 8:21 pm
Power: 197 rwkw
Excellent thanks.
I'll be getting some tomorrow.
Posted: Fri Jan 06, 2006 12:17 am
Ride: XHII pano, Landau
Gearbox- Fuchs TITAN 7590 95-90 semi synthetic
Diff- Fuchs TITAN ls-90
Found them both to be excellent
Automatics only come in assult riffles
www.aussiecoupes.net
Posted: Fri Jan 06, 2006 4:45 pm
Power: 197 rwkw
Actually on the Castrol website it says transmax Z is for autos. Dont like that idea.
Posted: Fri Jan 06, 2006 6:11 pm
Power: 197 rwkw
Just went out to get some Penrite 10 tenths 80w 140 and no one seems to stock it. I went to Auto One like Frank said and then Repco and the Veale auto parts and then supercheap.
Must be good stuff if its this hard to find.
Posted: Fri Jan 06, 2006 6:38 pm
You're meant to put ATF in T5s they shift really bad with gear oil.
plus the ATF will keep the bearings cooler.
Posted: Fri Jan 06, 2006 6:39 pm
you wont find it at regualar parts shops like that.
you'll have to look in some performance shops.
Posted: Fri Jan 06, 2006 7:20 pm
Ride: AU XR8
HI
i was told different i know ford recomend atf for the 6 cyl t5 .
but i was told that gear oil will keep the bearings cooler.
the guys at gearbox express said that they will not give warranty
if atf is used in a t5.
and i was also told that the v8 t5 is internally identical other than the length of the input shaft.. and ford recomends gear oil for the v8 t5.
so why do ford recomend atf for 6 cyl t5 and gear oil for v8 t5
when the gear boxes are the same.????????????
p.s. im not trying to be a smart a** im just quoting what i was told.
Posted: Fri Jan 06, 2006 8:02 pm
HI
i know every one has there own opinion on it. so it's cool man
i know mal wood says to use tranmax-Z and i've always used some for of ATF in my t5, and it copes a hell of beating...
when i first got the car it had gear oil in it and it would not go into any gear with out grinding,
Posted: Sun Jan 15, 2006 6:12 pm
Power: 197 rwkw
Well the car did have ATF in it and it was like water not very viscous at all.
I've put in Penrite Manual Gearbox Oil 75 and the gearbox feels a little better. Not as notchy as before which doesnt surprise me seeing as it was ATF.
All in all I wont be using ATF in a manual gearbox anymore. Next oil change I may even switch to Redline seeing as I'm now well versed in changing gearbox oil (seeing as I've done one manual gearbox oil change now :D).
It is currently Wed May 21, 2025 1:08 pm All times are UTC + 11 hours
