Cy4NiD3 |
I have a 94 EF Mont have just put it into self test diagnostic mode and got 3 flashes then pause then 3 flashes pause then it stayed on is this error 33 or whats the go with working out the codes?
Cy4NiD3 |
Anyone?....
grnxr |
Does this help...http://www.fordmods.com/forums/ABS-Diagnostics-d2.html?
I have to try it myself soon. |
Cy4NiD3 |
Ive allreayd read that ineed to know how many flashes etc represent the codes like code 47 is that 4 flashes then 7 or sumthing?... cuase im getting 3 flashes a pause then 3 flashes
grnxr |
I get that (33) from the dash ABS light but am not convinced - although it may be right. Did yours start after your engine re-install too? Will try the test via the diagnostic port using a LED tester next.
Quote from http://www.fordmods.com/forums/documents.php?doc=52: "The Self Test Codes can be read using either a Multimeter, or an LED, and consists of a number of Pulses outputted on the Engine STO Pin, and the Vehicle Diagnostic connector (The STO Out Pin is the 5th Pin from the left, on the upper row). These codes can be deciphered by using the format, 1/2 Second On Time for Each Digit, 2 Seconds Off Time Between Digits, 4 Seconds Off Time Between Codes, 6 Seconds Off Time Before and After the 1/2 Second separator pulse." Can someone please clarify whether the diagnostic port will/should give the same code as the ABS dash light, and confirm that you read the ABS codes from the ABS STO pin (7th from left top row)? Hope this isn't hijacking your thread. |
