station-rat |
Hi Guys
Can some one tell me what is the standard ride height for a EB wagon ![]() Thanks |
ausedwagon |
from my understanding it all depends on what options were picked. towbar, lpg... ect
BenJ |
If it is anything like mine was when I got it, then
REALLY REALLY HIGH!!!!! ![]() BenJ
station-rat |
Hi Benj
Have you had any problems with the diff from the height that your wagon is now? vibrations or noise Thanks ![]() |
racedirector |
Age: 64 Posts: 1584 Joined: 20th Mar 2005 Ride: EDL Fairmont Wagon/AU XR8 Ghia Location: Riverstone |
This was mine (ED) before lowering:
![]() And now with Lows in the front and 2" blocks in the back: ![]() Cheers RD
_________________ =1994 ED Wagon GLi body/EL Fairmont spec with *ALL* EL running gear.= |
BenJ |
Actually, no.
Unlike the the sedan, which rotates the diff through the suspension travel, the wagon diff mounted on Leaf Springs maintains a much better pinion angle when lowered. ![]() So at this ride height, and even lower with four adults, two large dogs, picnic gear, a full tank of LPG and a full tank of petrol, there is NO pinion rumble. The only issue would be on a large bump, the rubber bump stop above the diff centre would get a workout. But I have not yet experienced any crashing and banging etc. Mind you, I do have the Load Helper Springs, which stiffen the rear up with any sort of load in, which helps. I have 2.5" blocks in the rear, and S/Lows in the front. Cheers BenJ
surfn |
If the pinion angle is wrong, i think you can put in ' wedges ' from ( i think the later model 1 tonner utes ) to rock the diff into a different angle. Maybe a diff guy could clarify.
_________________ "In my opinion, my opinion is better than yours" |
ausedwagon |
ill get some photos up tonight or tomorrow. but ive just fitted kingsprings all around to my ed wagon and i have no problems
