Best replacement auto gearbox for EBII?
Page 1 of 1 [ 10 posts ]
 Post subject: Best replacement auto gearbox for EBII?
Posted: Sat Dec 20, 2008 10:49 am
Ride: EL fairmont offroader
My EBII auto may be on the way out. I would like to know what secondhand gearbox would be the newest, lowest kay for replacement. My impression is the BA auto is not really an option, but the AU might be?
wrecking 9/97 EL fairmont sedan burgundy 6cyl auto 270k modBAintake
Posted: Fri Dec 26, 2008 1:13 pm
bump
Posted: Fri Dec 26, 2008 1:54 pm
Ride: FPV BF MKII F6
an AU1 auto should fit, i dont know about the electronics side of things thoug
OBS35N is gooonnnneeee.
Gone for good..... Damn fence posts!!!!!
OBS35N #2 (XXF6XX) just bought, bring it on
Posted: Fri Dec 26, 2008 3:19 pm
Ride: EBII
Maybe just save yourself the trouble and get a reco or low K EBII auto.
Brand New Distributor: $50 + other stuffs
forums/viewtopic.php?t=73696&highlight=ebii
... "And the mountains shall drop sweet wine and the hills shall melt"...
Posted: Fri Dec 26, 2008 3:57 pm
Ride: SF5 Forester
AU will bolt straight up once you have swapped the bellhousing and i think the netural safety switch.
R.I.P Tobias my son.
Posted: Fri Dec 26, 2008 5:09 pm
Au ones are the smoothest shifting box but are known to fail more often. Best bet would be a ef/el one as they have a bigger oil pump in them over the eb ones. Also make sure you get the stall converter as well with the box as the eb one will not fit ef/au auto’s.
Posted: Thu Jan 01, 2009 8:57 pm
Where is the "neutral safety switch"? My EBII can start in neutral or park. Is the AU's system different?
When you say "stall converter" do you mean the torque converter?
Do you know of any other issues with swapping in EF/EL/AU box's?
btw, i am already using an AU bellhousing, because i have an AU motor.
Posted: Thu Jan 08, 2009 8:22 pm
I can pick up an EL fairmont with 255,000kms on it from just up the road for $900. It has a good service history, good driving history, and drives really well to me. I would much prefer a newer gearbox though.
Otherwise i am looking at $850 plus transport for a 160,000km AU auto with a 6mths parts and labour warranty.
Or $2000 for a reco box.
Posted: Fri Jan 09, 2009 11:09 am
I am told with the later AU auto's you need to swap in the earlier auto's switch, its a simple bolt/screw job.
It is currently Sun May 18, 2025 2:03 am All times are UTC + 11 hours
