swapping EA rear end for ED
Page 1 of 1 [ 10 posts ]
 Post subject: swapping EA rear end for ED
Posted: Sun Oct 05, 2008 9:19 am
Ride: EA fairmont GHIA
Ok guys...i was gonna continue my old thread but it doesnt really refer to what i want to know.......
What I've (potentially) got is a ED XR6 rear end and tailshaft.
Will this fit straight up to my EA fairmont GHIA, not worried about the ABS setup...but just the control arms, spring mounts, and watts linkage (anytihng else that could potentially be different)?
thanks..
5spd EA Fairmont GHIA, lowered Kings all round, 2.5" exhuast w/extractors, 3.45 LSD, Wade 1673 regrind cam, Alpine stuff inside
Posted: Sun Oct 05, 2008 10:19 am
Ride: AU XR8
it will fit..
the only issue you will come across is where the lower arms mount to the body.. ea have narrower bushes.. so you can either grind the inner spacers from the body of the ea so the ed arms fit.
or you use the ea lower arms and use large washers or spacers to fill in the gap where the narower ea arms bolt to the ed diff.
other than that just use the ed tailshaft and your away....
Posted: Sun Oct 05, 2008 10:32 am
Ride: V8 Falcon, Nissan Patrol
edfairmont4.0 used spaces, we never had a problem mate
Does the ed xr6 have the 3.45LSD?
If you want the ABS to work, just get some axles with the sensors fitted (I think EA Ghias were 25 spline, so they won't fit the XR6 diff (hopefully ur new diff has the sensors fitted)
1993 Ford Fairmont EB II 5.0L V8 Wagon
1992 Nissan Patrol TI 4.2L Diesel 4x4 Wagon
Posted: Sun Oct 05, 2008 10:48 am
thanks guys.
yeah i dont have ABS in my car so not gonna bother with it. can i just remove the abs discs and put my EA discs on it?
Its off a auto XR6 and i got a manual..will my tailshaft be suited rather than the xr6 one?
Posted: Sun Oct 05, 2008 11:52 am
thanks guys.
Yea, I wasn't sure if EAs had ABS, the sensors on the rear on the axles, front sensors are on the discs.
IIRC there are different tailshaft to diff bolt setups, but I think the change was between ED and EF, so you should be right, someone will confirm this for you. (But since you have the tailshaft that matches the diff, no worrys :D)
Posted: Sun Oct 05, 2008 12:34 pm
maddddd....i dunno how much i shoulda paid but i got the whole lsd rear end, tailshaft and the speedo transducer for $300
Posted: Sun Oct 05, 2008 1:53 pm
Thats a great price for a XR6 3.45 LSD with tailshaft and speed sender.
U'll notice the differance since EA autos were 2.77, 2.92 or 3.08s
Posted: Sun Oct 05, 2008 5:21 pm
Ride: 93 ED sedan
Power: 161 rwkw
The tailshaft is a straight fit. I have an EBII tailshaft in my EAI. I have the flange on too.
The EBII was an auto and my EA is a manual.
http://youtu.be/jJTh9F3Vgg0
Posted: Mon Oct 06, 2008 2:18 pm
Ride: 2000 Au wagon
my ea auto is 3.23.
Posted: Fri Jan 23, 2009 9:20 pm
my ea auto is 3.23.
as is mine
Users browsing this forum: No registered users and 28 guests
It is currently Mon May 19, 2025 8:22 pm All times are UTC + 11 hours
