ford383f |
"The following words in your search query were ignored because they are too common words: diff oil should use what i.
You must specify at least one word to search for. Each word must consist of at least 2 characters and must not contain more than 20 characters excluding wildcards." that is getting really annoying i have a 1995 XG Ute and was wondering the best Diff oil to put in it im sure this has been asked many many times but due to the awsome search feature means i have to spend hours looking through posts the label on the Diff is: 1TC 91OA-4005-TC S/NO Ratio 3.27:1 Cheers Eddie
_________________ 95' XG |
cjh |
If its NOT a Hydratrack, you could use an 85W140 or a straight 140 diff oil.
I use Penrite Limslip 140 in my EA.
ford383f |
How do i tell if it's a hydrotrack?
alfy |
Outback special edition utes got the Hydratrak diff IIRC.
_________________ 2021 V6 Manual Amarok - 245kw/750nm - many goodies |
ford383f |
any benifet to the hydratrack over standard or lsd? or just another ford invention of a name for a "special" series
alfy |
i believe the Hydratrak is a viscous LSD. not 100% though...
ford383f |
ahh ok
ford383f |
it's got 222,222km on it and i doubt the diff oil has ever been changed do you reckon it ever needs to be changed? or just keep it full?
it dosent leak and theres no noise from it but to check it you just pump oil into it untill it comes out correct?
cjh |
{USERNAME} wrote: it's got 222,222km on it and i doubt the diff oil has ever been changed do you reckon it ever needs to be changed? or just keep it full? it dosent leak and theres no noise from it but to check it you just pump oil into it untill it comes out correct? When the oil comes out, turn both the wheels so to help the oil spread around the diff and go through the bearings into the axle tubes.
ford383f |
cheers on that one
swoody19 |
yes the hydratrac is a viscous lsd
Users browsing this forum: No registered users and 23 guests |
