bushman |
hey, just got a new cushion button clutch an billet flywheel for my el 6cyl 5sp, put it all in right and triple checked everything and geuss wat its slipping
![]() ![]() the clutch is a `10.5 inch cushion button. we put new spigot bearing in, new throwout bearing in also its just mind boggling any help would be much appreciated
_________________ THE LOOSEST MUTHA FUKA YOU'VE EVER MET |
Krytox |
Slipping? a stretched cable would make it 'not' stick.
Bent fork could be a drama, but again, its part of a release mech. I could only assume the thrust bearing is too tall, or the flywheel is too thick. etc.
rushed |
did you put the plate in the right way around, a freind of mine got his clutch done, same thing slipping, the mating surface was the 6 flywheel bolts and the steel on the inner part of the clutch plate.
i know you said you tripple checked everything, but just a thought. |
alfy |
when i did my manual, the clutch slipped for about a day, only becuase when my mate put it on, his hands were covered in trans oil. it stopped slipping after it burned off and it was all good.
_________________ 2021 V6 Manual Amarok - 245kw/750nm - many goodies |
FLASH |
{USERNAME} wrote: did you put the plate in the right way around, a freind of mine got his clutch done, same thing slipping, the mating surface was the 6 flywheel bolts and the steel on the inner part of the clutch plate. i know you said you tripple checked everything, but just a thought. Exactly what i was thinking.
_________________ FALCAHOLIC |
Sturmovik |
If not greasy finger prints, did you clean the surface of the flywheel? It would have an .anti-rust coating on it
_________________ 1993 ED XR6 5speed Polynesian Green. Project car. |
Shum's EL |
{USERNAME} wrote: If not greasy finger prints, did you clean the surface of the flywheel? It would have an .anti-rust coating on it thats what i was thinking.. some brands have a very thick coating of it so it can take a while to wear off |
hans hartman |
{USERNAME} wrote: {USERNAME} wrote: If not greasy finger prints, did you clean the surface of the flywheel? It would have an .anti-rust coating on it thats what i was thinking.. some brands have a very thick coating of it so it can take a while to wear off did you sand paper the flywheel to rough it up a bit and remove the glazing,the pressure plate face does have a anti rust coating,and any greasy fingers, as for the assembly?too many maybees
low_ryda |
i usually burn off the protective coating before it makes it to the car with some metho & a lighter.never had a problem.
Shum's EL |
{USERNAME} wrote: i usually burn off the protective coating before it makes it to the car with some metho & a lighter.never had a problem. ^^^ pyromaniac lol |
bushman |
i worked and sorted out the problem it was a strange one but the cable was so bloody nackerd an stretched that we ran out of adjustment, its ok though i didnt drive it like that i parked her up and got a lift to work and fixed it later in the week so yeah $69 for a new clutch cable from autobahn springwood, now the clutch does everything i want it too,
umm whats the price of a t5 rebuild cause my synchros are fooked in second and just crunches unless below 3000rpm ![]()
bushman |
umm whats the price of a t5 rebuild cause my synchros are fooked in second and just crunches unless below 3000rpm ![]() ![]()
Users browsing this forum: Google [Bot] and 15 guests |
