ef suspension removal
 Post subject: ef suspension removal
Posted: Sat Sep 26, 2009 4:30 pm
can anyone shed some light onto the easiest way to remove the front struts/springs from ef/el
EF XR8: Mild engine work = 298hp @ 5600rpm and 510nm @ 4200rpm...skids
eyyyyyyy bloke u gotta spare namry or what
 Post subject: Re: ef suspension removal
Posted: Sun Sep 27, 2009 2:34 am
Ride: BF F6 Tornado - #0077
With spanners and sockets. Apply anti clockwise torque with a manual applicator (from looking down the threads toward the bolt head) to remove nut. Do process in reverse to re apply.
Please note, do not attempt to apply any form of torque to any fasteners in your car using your teeth. May result in a metallic taste
** For Sale ** {DESCRIPTION}
F6 Tornado 2006 {DESCRIPTION}
No?
Then f**k off
Posted: Sun Sep 27, 2009 3:37 am
Take you front rims off, remove your stub axles, unbolt the bottom of you shocks from the lower control arms the there are 3 bolts holding the top of the strut that can be unbolted from in the engine bay.
Posted: Sun Sep 27, 2009 12:16 pm
Don't worry about stub axles usually lower control arm is enough..
Users browsing this forum: Google Adsense [Bot] and 31 guests
It is currently Mon May 19, 2025 6:33 pm All times are UTC + 11 hours
