EF diff
 Post subject: EF diff
Posted: Wed Dec 02, 2009 2:26 pm
Ride: ED XR6, AUII XR8
Just pulled off a diff off an ef xr6 to put on my ed xr6 and noticed that the watt's link pivot isn't even lowered 20mm. The dif has a 94dt code , so it must be a 3.45lsd, but the dif cover has a code ending in 903 and was made in 95. the 903 code is the same as the ed. I have a 97 el dif cover on the ed and it had a code ending in 905, and is definately lower than the ef one. Whats up with that, i thought they all had the 20mm lowered pivot?
ED XR6, LeMans Red, 5-Speed
AUII XR8, Silhouette, 5-Speed
 Post subject: Re: EF diff
Posted: Thu Dec 03, 2009 12:27 pm
Ride: 93 ED sedan
Power: 161 rwkw
Only the EL's ( out of the E series ) had the 20mm lower pivot point on the cover. The EL's also had a different mounting point for the upper trailing arms, as well as different upper trailing arms.
http://youtu.be/jJTh9F3Vgg0
Posted: Thu Dec 03, 2009 1:21 pm
But didn't ford take the idea of the lower pivot from ef tickford cars, that's what i've read everywhere?
I also noticed this diff doesn't have the re-drilled (lower) holes for the upper trailing arms, but the ed does. I thought all tickford cars had these as well. As a side note the ef that i pulled the diff out of has 320mm upper arms:S
Posted: Thu Dec 03, 2009 1:58 pm
It is currently Sun May 18, 2025 7:16 pm All times are UTC + 11 hours
