Brake Pedal Soft?
Page 1 of 1 [ 13 posts ]
 Post subject: Brake Pedal Soft?
Posted: Tue Nov 24, 2009 3:48 pm
Ride: Ford EB II Falcon
Hey guys recently my brakes have been shuddering and i thought it was because there was air in all the lines but today i bled the rear brakes and air only came out of the Left side and the right side was fine ! So now my pedal is soft not heaps sensative and doesnt give the spongy/air feeling. Also i couldnt find out what way the front bleeders went so thats the reason i didnt do the fronts !
So is the soft pedal i have fine to drive around with?
OLD CAR: EB II Falcon, Everglade Green, 250thous (Rough Guess), Wildcat Extractors, 2.5 Exhaust with Muffler + Hot Dog, 18 Inch Rodney Jane Mags, XH Snorkel, EA MPEFI Tubing !
NEW CAR: 1996 TE Magna...Mods Soon To Come
 Post subject: Re: Brake Pedal Soft?
Posted: Wed Dec 16, 2009 3:04 pm
Ride: XF Panelvan
i wouldnt if i was you, probly best to take it to a brake place if bleeding didnt do it
Double legger stock EF fairmont. 15.46 1/4 mile
Posted: Wed Dec 16, 2009 3:09 pm
Ride: 1993 EB XR8
Check the rotors. If it is shuddering, then 99% of the time you will have warped rotors
Posted: Wed Dec 16, 2009 3:47 pm
Gallery: 21 images
Ride: EL F100 CAPRI XR EF
Power: 234 rwkw
soft pedal is from air in the system, from when u changed masters, needs bleeding more front and rear.
shuddering in the steering is front discs, shuddering in the brake pedal is rear discs
only costs $55 for the mobile guy to machine them on the car, thats the pair.
just have your car jacked up calipers hanging to one side and axles stands under the body, takes 10mins per side
Posted: Wed Dec 16, 2009 4:02 pm
Ride: ef falcon, el fairmont ghia
the fronts are the same as the back how couldnt you figure that? and yea it would still have air in lines
Posted: Wed Dec 16, 2009 7:08 pm
Ride: Falcon EL Option 20
Try get it fixed as soon as possible... You don't want to slam the brakes really hard and find that it's only pushing air, and your not braking... Trust me it's not fun.
Posted: Fri Dec 18, 2009 10:17 pm
Ride: 93 ED sedan
Power: 161 rwkw
Did the brake fluid look like this before you started????? Not good!!!!
http://youtu.be/jJTh9F3Vgg0
Posted: Fri Dec 18, 2009 10:50 pm
Nope it looked in between that and a clear yellow ! but still it is bad !
Posted: Fri Dec 18, 2009 11:05 pm
Ride: 93 ED sedan
Power: 161 rwkw
Does it look like this now???
Posted: Fri Dec 18, 2009 11:40 pm
Ride: BF F6 Tornado - #0077
got any more info on this? need to get mine done soon. just a mobile service van? like lubmobile?
** For Sale ** {DESCRIPTION}
F6 Tornado 2006 {DESCRIPTION}
No?
Then f**k off
Posted: Sat Dec 19, 2009 12:49 am
Gallery: 21 images
Power: 234 rwkw
here in sa theres a guy who advertises in the local paper, ive used him 3 times, $45 for front or rear pair machined. went up to $55 pair in october. there are also a couple more that advertise in the yellow pages under brake and clutch services. all mobile vans, they have another lathe in the back of their vans for hard to do discs or can do your rears in the van whilst doing the fronts on the car.
you just need your car jacked up wheels off and on axle stands with the calipers haging to 1 side.
he bolts his machine to your hub/disc and machines them on the car, takes about 10-15 mins depending on whether he needs to take a 2nd pass or not
Posted: Sat Dec 19, 2009 10:19 am
I wish !
Posted: Sat Dec 19, 2009 10:26 am
do more skids it'll harden you up
Users browsing this forum: Google Adsense [Bot] and 5 guests
It is currently Sat May 17, 2025 9:01 pm All times are UTC + 11 hours
