diff and gearbox
Page 1 of 1 [ 8 posts ]
 Post subject: diff and gearbox
Posted: Thu Dec 17, 2009 2:59 am
hi all. just after some info
I've got a diff out of a ef v8 wagon that's got a 3.23 ratio and also has a performance diff tag on it . dose that tag mean LSD or v8 diff.
2. whats the difference between the I6 gearbox v8 box
 Post subject: Re: diff and gearbox
Posted: Thu Dec 17, 2009 9:43 am
Ride: 1993 EB XR8
1. Performance diff is 4 Pinion open centre
2. Alot. Input shaft length, Bellhousing, gearing
Posted: Sat Dec 19, 2009 5:53 pm
so the tag just saying that it's a v8 diff . not a lsd
thank's for the info
Posted: Sat Dec 19, 2009 6:11 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
There is no difference between a i6 diff and a V8 diff.
As above, its a 4 pinion center, it can be LSD or Open.
The High Performance basically states it has 4 spider gears as opposed to 2 in a lower end diff.
Posted: Sat Dec 19, 2009 6:49 pm
Ride: 93 ED sedan
Power: 161 rwkw
I6's tend to have a 2 pinion open centre...standard ones.
The V8's can have either a 4 pinion open centre or a 4 pinion LSD centre.
http://youtu.be/jJTh9F3Vgg0
Posted: Sat Dec 19, 2009 11:21 pm
ok thanks for info guys .... as for the gearbox can the I6 T5 be modified to fit the 5.0l
Posted: Sun Dec 20, 2009 2:58 pm
It has been done, but involves modifying the input shaft length. Look for Banarcus' thread.
BenJ
{DESCRIPTION} - Current Ride
{DESCRIPTION} - Previous Ride
Posted: Sun Dec 20, 2009 3:07 pm
Ride: 1993 EB XR8
EB2 onwards all Falcons got the 4 pinion until the BA.
Users browsing this forum: Google Adsense [Bot] and 17 guests
It is currently Mon May 19, 2025 4:33 am All times are UTC + 11 hours
