lighter power steering El
 Post subject: lighter power steering El
Posted: Wed Sep 25, 2013 10:34 am
Gallery: 5 images
Ride: EL GLi
My mate has a ford au s2 and his steering is alot better than mine i was wondering if anyone knew how to get lighter steering in a El Gli i6
 Post subject: Re: lighter power steering El
Posted: Wed Sep 25, 2013 11:39 am
Power: 148 rwkw
I have the same situation: the steering on my AU2 is way lighter than on my EF. Both are I6s, both have the same tyres, so have no explanation for the difference other than that's the way they are made.
Posted: Fri Sep 27, 2013 9:11 am
Gallery: 5 images
Ride: 2021 Amarok V6
Could install a Ghia speed-sensitive setup.... not sure if you need to change the rack over or not.
Posted: Fri Sep 27, 2013 4:04 pm
Ride: 96 XH/97 EL
You do need to fit an SSPS rack + EL Ghia or NL Fairlane ECU. The SSPS plug is already in EL Futuras and above - don't know if GLi's are in that too.
Users browsing this forum: No registered users and 19 guests
It is currently Fri Jun 20, 2025 6:40 pm All times are UTC + 11 hours
