presto |
anyone know if you can fit an ed manual into an auto au falcon? would it bolt straight up or is it different?
did a search but didnt find much and too lazy to syphon thru 400 pages incase theres a reference thrown in there somewhere. cheers in advance ![]()
_________________ I will not eat oysters. I want my food dead. Not sick. Not wounded. Dead. |
TROYMAN |
yes it can bolt up. but if you use ed bellhousing the lower 2 bolts dont line up,
if you can get an au bellhousing the ed box will bolt to that.. BUT the major issue, probably making it not a good idea is, the ed shift sits about 2" further forward compared to the au box... so the shift wont line up with the hole in the floor or console... |
sd1800 |
As troyman said, don't bother. The shifter will come up near the ashtray in the AU.
You have to source a AU box. You also cannot use a V8 box in a I6 and vice-versa.
_________________ Formerly LV XR5 Turbo, AU Fairmont Ghia V8 & EBII Fairmont I6. |
presto |
no worries, thanks for the info. they looked the same from what i could see (only had a quick look under an au at work) but wanted to make sure.
was going to put it in my mates au but i guess not now ![]() For sale: ed gearbox, clutch, flywheel and pedal box ![]()
