Can any borg warner diff modify & fit a FALCON
Page 1 of 1 [ 5 posts ]
 Post subject: Can any borg warner diff modify & fit a FALCON
Posted: Fri May 14, 2010 5:58 pm
Ride: EF Falcon GLi
Hi guys can i use R31 skyline, pitara or something diff in a falcon?
Now, I've got a message for all the other drivers out there. If you smell a delicious, crispy smell after the race, it's not your tailpipe. It's just a little of Shake...and Bake!
SHAKE AND BAKE
 Post subject: Re: Can any borg warner diff modify & fit a FALCON
Posted: Sat May 15, 2010 1:45 pm
Gallery: 17 images
Ride: 5.0lt NF /351 ZD Fairlane
You can use the gear set easy enough. :D
NF Fairlane with 5.0 and 5 speed goodness!
XE Fairmont Ghia
Posted: Sat May 15, 2010 1:51 pm
Ride: AU XR8
why would you want to do that??
the diff is shorter, it has 4 stud axles...
better of just using the gears from it...
Posted: Sat May 15, 2010 2:47 pm
Ride: EF Falcon GLi
Well i no that, but the gears require a pro to put in, and cost hundreds. i wanted to no if they can be modified to fit a Falcon because there all similer?
SHAKE AND BAKE
Posted: Mon May 17, 2010 2:33 am
Ride: Lincoln LS, MKII Escort, ED
post count says not a troll but last few threads by you say might be.....
No, the borg warner diff as fitted to commodoores,falcons,cortinas,skylines and pintaras although similar will have very different widths,brake setups and suspension mounts - not to mention that some are weaker with 25 spline axles and 2 pinion LSD's and some stronger with 28 spline axles and 4 pinion LSD's, and modifying the basics such as the suspension mounts is best left to the pro's or done by somone who doesnt need to ask. Your best off sticking to post EB/ED/EF/EL diffs for your falcon as they all share widths, stud pattern, basick brake setup (you can mix and match parts easily enough) and swap over with minimal suspension tweaking (some require trailing arms from the donor car)
Because i can.
Users browsing this forum: Google Adsense [Bot] and 23 guests
It is currently Sun Jul 13, 2025 5:38 pm All times are UTC + 11 hours
