speedo is out 10 km
Page 1 of 1 [ 15 posts ]
 Post subject: speedo is out 10 km
Posted: Sun May 23, 2010 11:16 pm
Ride: ef falcon
hey guys i recently put a fairmont ghia speedo in my ef gli its got a ef xr6 manual in it and 345 diff ratio the standard speedo used to show 100 kmh when the revs where at 2000 rpm in 5th now with the new speedo at 2000rpm the speedo says im doing 90kmh does anyone no how i can fix this or re calibrate it? cheers
 Post subject: Re: speedo is out 10 km
Posted: Sun May 23, 2010 11:36 pm
Ride: EF Falcon GLi
Bigger rims :twisted:
Now, I've got a message for all the other drivers out there. If you smell a delicious, crispy smell after the race, it's not your tailpipe. It's just a little of Shake...and Bake!
SHAKE AND BAKE
Posted: Mon May 24, 2010 12:42 am
Ride: 2.0 Turbo VW
Power: 142 rwkw
change the speedo gear, use the search
Posted: Mon May 24, 2010 2:53 am
Ride: EF Falcon GLi
Thats the litle yellow thing hay?
SHAKE AND BAKE
Posted: Mon May 24, 2010 8:45 pm
Ride: EF Fairmont Sedan
Power: 180 rwkw
Click the resources Tab and look in there
Or click here documents.php?d=30
PROEF 13.46 @ 105.78mph - 1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
Stock Fuel Pump, 29lb Injectors, JMM Street Series Headers, 2.5" Exhaust, 205rwkw
Posted: Mon May 24, 2010 10:42 pm
Ride: ef falcon
hey guys thanks for helping here but the thing i dont get is how the gli cluster was spot on with the speed and now i put the ghia cluster in its out now and i haven't changed wheels or anything
Posted: Mon May 24, 2010 11:13 pm
Ride: EF Falcon GLi
Maybe it was the GLI that was broke... :shock:
SHAKE AND BAKE
Posted: Mon May 24, 2010 11:24 pm
Ride: 1993 EB XR8
English please?
Posted: Mon May 24, 2010 11:28 pm
Ride: EF Falcon GLi
English please?
The GLI cluster...or maybe there not calibrated the same as XR6 ones
SHAKE AND BAKE
Posted: Mon May 24, 2010 11:30 pm
Ride: ef falcon
what im trying to say is changing the cluster shouldnt effect the speedo readings nar the gli cluster was spot on with the speed
Posted: Mon May 24, 2010 11:42 pm
Ride: EF Falcon GLi
Oh can only be a faulty cluster then
SHAKE AND BAKE
Posted: Mon May 24, 2010 11:43 pm
Ride: EF-XR8chaser
ghia cluster was auto and 323 diff?
R.I.P HANS HARTMAN
Posted: Tue May 25, 2010 1:21 am
Gallery: 18 images
Ride: Envi EF
Doesnt make a difference to the clusters.
With a 3.23 diff + 5 spd (EF) I was on 2k rpm @100kmhr, with 3.45s I sit on a smidge under 2200 rpm @ 100kmhr so I'd be double checking with a gps or against another car what speed you're actually doing.
>>>{DESCRIPTION}<<<
Posted: Tue May 25, 2010 10:25 pm
Ride: ef falcon
cheers guys i havnt acally checked with a gps i was just going off other cars on the road and how the 2 clusters read differently ill go for a drive 2moz and try it out with the gps thanks for the help
Posted: Mon May 31, 2010 9:38 pm
Ride: ef falcon
haha i found the problem guys the guy i bought the cluster off put el back grounds instead of ef when he put the needle back on he didnt sit it on zero he sat it bout 10mm below 0 all i got to do is pull it apart again but i appretiate your help guys
It is currently Tue Jul 08, 2025 2:36 am All times are UTC + 11 hours
