theregisteredone |
Posts: 12 Joined: 30th Jul 2009 |
I have a 97 NL Fairlane (6cyl) with factory auto. I have owned it for a couple of months and ever since I've had it, it's had a transmission issue. I am not sure where to go with fixing it, and I'm hoping that someone (or two) here could help me.
I only ever drive in 'Economy', and that is the situation below. Switching to 'power' makes no difference. I am about 99.9% sure the problem has nothing to do with the switch, and in economy the light on the cluster comes on. When the transmission is cold after leaving overnight, it has no issues. It shifts at the right time and smoothly without any other issues. Also, the economy/power switch works correctly at this stage. However after driving for about three minutes the first to second shift (up and down) gradually gets harder, and also begins also to hold for longer and longer until the engine temp reaches about half running temp (just below the letter 'L' of normal). By the time it reaches that temperature, it is holding the first gear (this is in Economy) until about 2200rpm at light to mid throttle. Also, by this stage the shift up is a horrific slamming kick. ![]() At this temp and up, I also have issues with kickdown. It kicks down to too low a gear and appears to lock (or spin, not sure) the rear wheels. Coming to a stop, I also get a small kick when it shifts down. I am not too good with transmissions, however doing my research, I am leaned toward a solenoid. I do not know which one (possibly S5?). If anyone could help out here with suggestions, I would be very grateful. I am trying to figure out exactly what the issue is with my current transmission, and possible ideas to fix it. Plus, any comments on my below ideas would be nice! ![]() I really do not have a lot of money, and while I would just love a full rebuild, I simply cannot afford it. Also, thanks to the first gear holding my fuel consumptionis going through the roof, regardless of how softly I drive it. I took the car to one of only two auto specialists in Newcastle (that I know of), and this person has driven it twice and said that he is not sure, but "it could be a solenoid". He said I'd be looking at about $600 for a new solenoid fitted. If you've read through this far, thanks! ![]() Let's say it was a solenoid, what would be my best options? I'm currently thinking:
![]() Thanks for help in advance! ![]() |
theregisteredone |
Arrgg... Surly someone could comment on it....
In fact, quick update. Two days ago, I switched it to 'Power' and floored it around for the day, redlining and carrying on, and then yesterday I switched it back to economy when I got in it in the morning and it drove right up until about 10am today with no problems. No hard shifts, and no holding gears too long. It was excellent. ![]() ![]() Since 10am today though, it's gone back to the way it was... ![]() ![]() Seeing what it could do yesterday, I am thinking I might just keep this box if it just needs simple repairs. Ideas anyone ![]() |
jaysway |
has it been serviced recently?
i dont think the nl had adjustments for the band on the side of the box but a flush, new oil and filter would be a start. someone correct me if they did have band adjustments on the side. an AU auto will fit, im sure you could find a good low KM second hand one cheap enough. id rather do that than go to an auto shop were he is not sure. also your cars water temp sits too high for my liking which could be causing the auto temp to get too high, does it have a seperate auto oil cooler? |
theregisteredone |
I only bought it about three months ago, with no history...
![]() ![]() I am slightly inclined toward the AU transmission, and am I correct in thinking that it is a direct bolton with a bellhousing change-over? Yes, there is a factory-fitted transmission oil cooler, of which I am interested to know if was fitted as standard to NL Fairlanes... It also has a factory fitted towbar and wiring, so I'm guessing it may have been part of a tow pack perhaps? The towbar also makes me wonder if it has been used for some heavy towing. At least it isn't the heavy-duty bar... As for the temperature, when I bought the car the thermostat was stuck open and the car never heated up to the normal range. I replaced the stuck (aftermarket) thermostat with a genuine Ford one and since then it has always sat around the letter 'M' of normal at maximum. Keep in mind that these have 'normal' running downwards with the 'N' at the top (see pic). You can actually see in the pic the low coolant light. I'm not certain, however I believe that it has a small leak from the header tank. Never has over-heating problems, though. By the way, I put it into 'Power' mode, put my foot right down and redlined it again and then put it back to 'economy' and it's shifting right again. ![]() ![]() |
jaysway |
sorry i forgot the ef el temp guages are the other way around compared to eb ed.
if you do the service your self it wont cost that much at all. have you at least had a look at the color of the oil? wouldnt suprise me if its black, if so do the service asap. and stop redlining it in the mean time. |
theregisteredone |
Thanks for replying!
![]() Yes, I guess I should stop doing that... ![]() ![]() No, I have been a bit lazy there, I haven't checked the oil. I know, I know; "arg, what an idiot, that'd be the first thing..." It's just a bit difficult with the whole sealed transmission thing, and I am still unsure of exactly when you should remove the filler plug to check the level. Coming to think of it though, I think the owner manual had good directions for it, but maybe I'm wrong... I have the impression that the whole car has been quite well maintained, so I am assuming it's last auto service wasn't too far off. When I did the engine oil, I didn't really seem to old. That said, autos (esp. sealed autos) are generally quite neglected when it comes to servicing. I'll check the oil today, if I find the instructions. I really should get a workshop manual, eh? |
newbiefordstar |
howsit fella...i know this is a bit late (a bit too late to reply) but did you end up getting your transmission fixed? ...i had problems with my transmission a year after i bought my nl fairlane ghia. if you have got it fixed...good on ya mate
One Drone |
My first port of call would be to top up the tranny oil. If that fails do one "tranny dump" and put fresh oil in. After that, for an I6 it will be cheaper to get a 2nd hand tranny with warranty and replace.
