DormanAU |
how can i remove the front wheel hub off, its a 35mm nut holding the hub on, but my socket set only goes to 32mm.
please heap.
_________________ Au factory 5sp, rolling on 20'z, full custom extractors, redback cat and back. has a new motors, only 27,000ks |
lukey1990 |
Borrow the correct size socket from a mate, or a local garage?
Or buy one from repco, they should sell them individually and they are of reasonable quality too.
DormanAU |
live out of town and every thing is closed, just sent a mate home to look if he has one.
Stu5766 |
Age: 43 Posts: 78 Joined: 15th Jun 2010 Ride: XD Fairmont Ghia 351 Location: Blue Mountains |
G;Day.
Try a local truck repair shop. 35 mm socket is more common in 3/4 drive socket sets. Cheers Stu. |
DormanAU |
we found one and got the hub off, but one of the bearing caps decided to sieze its self on the stub axle, got it to move about 2 mm. cant get a balencer puller in there so im gonna make a slip over thingy, slightly bigger then the stub axle but smaller then the bearing cap and sticks out around it, so i can use the puller to pull the cap out.
Stu5766 |
You could very gently grind the remaing inner case and split it off the stub axle.
DormanAU |
thats plan b for tomorrow.
James84 |
{USERNAME} wrote: You could very gently grind the remaing inner case and split it off the stub axle. or a short weld or 2 on it. |
Disco Frank |
spray in some crc
and belt the f**k off with a hammer the hub is f**k anyways ![]() thats what i had to do with my AU on both sides then some nice emry cloth to smooth the spindle and re grease the spindle!
_________________ RIP SCOTT |
DormanAU |
all up and running, is was just an inner cap stuck on the stub axle, used a die grinder cut a slit thru the cap till it was fairly thin, hit it with the coldchisel and cracked and just pulled it off.
cheers for the help.
Users browsing this forum: Google Adsense [Bot] and 37 guests |
