leopard |
I try replace my Ignition Coil Pack in my ef station anyone nows how to do this
frd906n |
either jack the car up from the front, put something under so it dosent fall on you, and you should be able to acess the coil pack from under neath on the passanger side, make sure u remember where each lead goes, or you can take ya air box out shove ya arm under the intake manifold and feel for the coil pack and do the same thing
_________________ Daily Driver, Series 1 Au Forte Quote: Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
