ba hyd clutch in au.
Page 1 of 1 [ 9 posts ]
 Post subject: ba hyd clutch in au.
Posted: Wed Sep 29, 2010 10:29 pm
Ride: AU falcon
Can I use all the ba t5 clutch gear like bellhousing, thrust bearing, pedal, master cyl and lines in my au.
Need new cable so thought I could upgrade as I'm sick of the heavy clutch due to a knee injury from years ago. Funny story but is annoying on the clutch
Also no I'm not getting an auto.
Cheers for any advice.
Au factory 5sp, rolling on 20'z, full custom extractors, redback cat and back. has a new motors, only 27,000ks
Welcome to Toongabbie motorsports :P
 Post subject: Re: ba hyd clutch in au.
Posted: Wed Sep 29, 2010 10:35 pm
Ride: AU2 Ute
It doesnt all just bolt in but its doable.
You'd need the box too because the slave cylinder bolts to it. I imagine the input shaft lengths are different or something too.
The BA bellhousings look thinner.
Posted: Wed Sep 29, 2010 10:40 pm
Ride: 1993 EB XR8
And know where you can get most of that stuff too :lol:
Posted: Wed Sep 29, 2010 10:41 pm
Ride: AU falcon
Bugger, was hoping it would all slot in. Looks like just getting a new cable, after 240,000 would be greased up at all plus the cover is peeling off.
Posted: Wed Sep 29, 2010 10:47 pm
Ride: AU2 Ute
Mal Wood can sell you everything to make it bolt in easy.
Posted: Wed Sep 29, 2010 10:50 pm
Ride: 1993 EB XR8
So can I :lol:
Posted: Thu Sep 30, 2010 10:56 am
Ride: AU falcon
I'm interested, pm sent
Posted: Thu Sep 30, 2010 10:21 pm
Gallery: 17 images
Ride: TS40
how olds your clutch? my original one was pretty heavy (surprised my firewalls still in one piece, i think my pedal box has been repaired) when my throwout bearing seized i got a exedy clutch kit put in at abs brakes morwell and its now a heap lighter, defiantly not hydraulic but not bad.
this is the clutch kit i got exedy FMK-6913
Was - {DESCRIPTION}
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
Now - {DESCRIPTION}
Swift Green,6 Speed Auto, Stock... and a Fuel Card :)
Posted: Sun Oct 03, 2010 12:26 pm
Ride: AU falcon
Clutch is only 2 years old, 50,000 ks. Looking at new clutch cable, should help a touch. Might be worth looking at a new clutch like the one fourl6 mentioned.
It is currently Mon May 19, 2025 6:09 am All times are UTC + 11 hours
