Have gas system, need mixer - suggestions?
Page 1 of 1 [ 8 posts ]
 Post subject: Have gas system, need mixer - suggestions?
Posted: Tue Oct 21, 2008 3:27 pm
Ride: EDL Fairmont Wagon/AU XR8 Ghia
Hi all
I just finished pulling the gas system out of my old EA wagon in readiness of having it installed in my ED wagon. I have a Sprintgas 70L donut tank and an OMVL R90E converter. This system was on a 3.9 CFI. I have pulled everything out including the copper line. Now all I need is a mixer for MPFI and to install it/have it installed.
What sort of mixer should I be looking for or doesn't it matter? I was going to go off to the wreckers and see if anything there has one on and grab that.
Budget is tight so I was going to install everything but the lines and wiring but was going to take the current copper line to the installers to see if they could use that to reduce costs.
Anyway, any heads up info on the mixer would be great..
Bruce
=1994 ED Wagon GLi body/EL Fairmont spec with *ALL* EL running gear.=
Build Thread: viewtopic.php?f=53&t=65695
=1998 EL Futura Sedan - The EF Fairmonts Replacement=
Build Thread: viewtopic.php?f=53&t=106588
Posted: Tue Oct 21, 2008 5:09 pm
Well, it seems I didn't have everything. I went to check the bits and found I didn't grab the plug that plugs into a black thing in the converter to mixer line. After digging round under the dash, I found a box that said Computerized LPG System. Wires from that box have been spliced into the ECU main feeds.
Is this normal? What kind of system is this? And lastly, will this install OK into my ED without the need for things like a new ECU?
I'll take pics of everything I have if that helps any.
Bruce
Posted: Tue Oct 21, 2008 5:25 pm
Ride: MCMXCV Falcon
Ssounds like your in over your head
why dont you check with the conversion guy first
Posted: Tue Oct 21, 2008 5:39 pm
I think you are right. I'll install all the basic system and get them to quote for the rest.
Posted: Wed Oct 22, 2008 3:05 pm
Sorry to bump this, but I am still after what sort of mixer I should grab for the converter I have. If anyone can suggest something, I'll know what I have to look for.
Bruce
Posted: Wed Oct 22, 2008 3:19 pm
Ride: MCMXCV Falcon
any ring mixer of suitable external diameter...doesnt matter
Posted: Wed Oct 22, 2008 3:25 pm
Cool, thanks.
Posted: Wed Nov 19, 2008 10:05 pm
Ride: turbo ef falcon
any mixer, gra or impco id recommend. im using impco and since its basically a carby style mixer as long as you have your lock offs hooked up to the fuel pump relay or something then it will work with standard ignition.
I will not eat oysters. I want my food dead. Not sick. Not wounded. Dead.
It is currently Tue May 20, 2025 3:11 am All times are UTC + 11 hours
