bluestripes |
Hi All
Can I get some thoughts on the best LPG system, re performance for my AU Ford. Currently it's an after market dual fuel system, though with a new top end upgrade, I've disabled the old dual fuel till I can source a better system. My mechanic recommend I look at GRS, and I've read a bit about Orbit. It would be good if I could use the my old LPG tank and other bits to keep cost low. Money is also alittle tight at the moment finally - top end upgrade is TF 170 cc heads, street burner manifold, stage 1 cam, 70mm Holley TB, 24lb TF injectors, 76mm pro-m Maf. Custom CAI, performance extractors with 3 inch pipe. Thanks guys Experienced feedback very welcomed
_________________ AU Ute ~ R350 |
MICKYYYY |
GRA would be your cheapest way out then Emer if they have injectors to suit hp level or landi renzo.
U will have to check and see what size your current LPG lines are, as u may have to go bigger.....
_________________ Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc[/SIZE][/size][/color] |
tickford_6 |
Emer,
failing that JTG liquid injection, though it will mean a new tank. Any non injection system is only going to cost you power. |
