StevenBruzz |
Other day i noticed my boot lid had alot of vibration when tapping on it but untill today when fitting subs in the boot did i know how bad it is is there anyway i can stop the vibration while bein abe to get full potentional out of my system
Matt_jew |
Fit dynamat , stinger road kill etc sound deadening to inside the boot lid etc.
Johnson stroker |
Tou will dinf the original bonding has persihed. it goes hard and brakes out and rattles and vibrates.
You will need to remove the bootlid, use sikaflex and reglue the bracing to the skin. Allow it to fully go off. then as EVL098 said, use dynamat of a similar product on the boot. this will remove 99% of your VS Commodore bootlid spec issue. also while you have the bootlid off, remove as much of the hard broken bonding agent as possible. I have had the displeasure of this stuff finding its way into the boot latch and jamming the mechanism not allowing to the boot to open.
StevenBruzz |
Yeah thats exactly whats happened
I was pumpn it at the servo last night n a blOke suggested foam wedged up in the bracing so im gunna try that with silicone proberly i cbf pulling boot off and removing bracing cuz my luck il fuk it up |
bry40l |
i jammed towels in between the boot and the interior piece that is on the boot lid, it shut some of the loud rattles up and was much better but definatly pull the yellow glue s**t out from the bracing and redo it
_________________ BF XR6 |
wmp |
just don't go over board like i did on my last EF...
you don't have to use the whole tube of silicon for it to work.... puts to much stress on the gas struts. though did fix the rattle. all was left was the number plate. and some bubble wrap behind it worked quite well ![]() |
Users browsing this forum: Google [Bot] and 25 guests |
