winman |
ok yes ive searched.
the car is using the stock standard system (ba mk2) im planing on installing an amp + 6 inch round speakers, with future hopes for a sub. the only part of this im really confused about is how do i get over the hurdle of no RCA plugs from the stock ICC. do i need to put a line converter to convert from high to low at each speaker or just one from the ICC, if from the ICC which wires do i cut into to install it. also how are you guys mounting your amps, i was just thinking a inside the boot under the parcle shelf via a bracket. any other info would be apreciated. thanks edit: if anyone in the future has the same question as me, they are mounted between head deck to amp. as your amp takes in the low level.
_________________ BA XR6 Last edited by winman on Tue Feb 14, 2012 10:59 pm, edited 1 time in total. |
ba_xr6bw |
My amp is under the passenger seat. Wires run through the bottom door sill.
Was installed by strathfield so couldn't tell you about the icc. I've got my sub on eBay ATM item number 150747933572 If you keen
_________________ BANNED USER |
winman |
thanks for that. im actually using the underseat space to put a small 8" sub
so far ive installed 4 speakers with much swearing and MDF spaces that i made up. sounds pretty good so far, it only starts to distort when the music is turned up past 25.
_________________ BA XR6 |
ba_xr6bw |
Hey I just bought 2 tweeters and the ghia trims for them!!
Can I just cross them with the door speakers or what?
BEAR80 |
Age: 45 Posts: 683 Joined: 4th Mar 2010 Ride: BF Fairmont Ghia & TS Magna Location: central coast |
{USERNAME} wrote: Hey I just bought 2 tweeters and the ghia trims for them!! Can I just cross them with the door speakers or what? start your own thread for asking questions |
ba_xr6bw |
It's easier this way man
winman |
ok well an update. system is installed and then resetup. im in the process of ironing out noises.
its a 4 speaker system with a amp. incase down the line someone has the same question as my original, the high to low line converters are to be installed between speaker-amp lines. I installed mine just before the amp as it was easier for mounting
ba_xr6bw |
Nice work. You interested in the pillar tweeter part out of a ghia?
I have a set on eBay in mint condition. If so I'll give you the item number and you can check them out
winman |
nah im alright, wiring to the bottom of the kick pannels was a nightmare alone to get to. no way i could be bothered to go further up lol
ba_xr6bw |
380410117412 eBay item number, 30$ starting bid
ba_xr6bw |
^^^ there in mint condition not a mark or stain!!
ba_xr6bw |
They fit any ba or bf!
BEAR80 |
{USERNAME} wrote: Nice work. You interested in the pillar tweeter part out of a ghia? I have a set on eBay in mint condition. If so I'll give you the item number and you can check them out Go an make your own thread and then stuff it up, I hope you get banned ![]() |
ba_xr6bw |
I really don't think winman cares that much. This site is about sharing and trying to get alone with others. Only person who is stiring s**t is you. You should be banned for life
winman |
Quote: I really don't think winman cares that much. This site is about sharing and trying to get alone with others. Only person who is stiring s**t is you. You should be banned for life it is considered rude to hijack another persons thread. i personaly dont care as it doesn't anoy me. however if your looking at selling your parts how is having them advertised in a thread named "ba, how to wire up aftermarket sound system" going to help you sell. post it in the for sale section and you will probally get a few hits.
