Full Car Audio
 Post subject: Full Car Audio
Posted: Fri Apr 14, 2017 10:54 pm
Ride: 2009 XR6 FG
I am wanting to put new speakers and subs in my car, But i dont know much about about it.
I heard RockFord are a good brand, I choose 2 12' P2D4-12.
Im not sure what amp i need to wire them up,
Was also planning on getting pros to wire in a converter so i can keep the standard head unit.
any help is appreciated
 Post subject: Re: Full Car Audio
Posted: Fri Apr 14, 2017 11:53 pm
Power: 144 rwkw
If you plan on running 2 x P2D4-12, you will need a pretty decent amp to power them both. I suggest minimum 800W RMS output since each sub has a 400W RMS power rating. Just make sure you know at what Ohms the output is of the amp to determine how you run the wiring. If you plan on getting professional to install, they will be able to guide you to an amp with suitable output for the subs you want.
Have you looked at other brands of subs? Is this just for everyday use or are you aiming for SQ/SPL quality?
phongus = Post whore 2006
Posted: Sat Apr 15, 2017 10:58 pm
Ride: 2009 XR6 FG
thanks phongus, no, havnt really looked at other brands, ive seen so many brands and dont really know what the difference between them all are so i just went with the first brand my mate told me.
They are mainly for everyday just cruising just something nice to listern too.
Do you suggest a better brand of subs or amps?
ive heard pioneer are a ok brand too.
It is currently Sat May 17, 2025 8:49 pm All times are UTC + 11 hours
