RCA cords, how long? etc
Page 1 of 1 [ 6 posts ]
 Post subject: RCA cords, how long? etc
Posted: Wed Aug 17, 2005 3:20 pm
Ride: ef fairmont ghia
just wondering how people have run their RCA cords and how long they are
i have 3 RCA
1xfront
1xrear
1xsub
all run from deck, under centre consul, under carpet behind driver, under rear seat where 1 goes to factory amp (5m length - just reaches) and 2 (fronts and sub 2x8m - way too long) go up shock/spring tower then under rear parcel shelf to amp mounted where stock sub was.
has anyone measured whats needed if i am to make my own and does anyone run the cables a different way??
Sometimes when you do something right, people wont be sure you've done anything at all. (Futurama, Episode - Godfellows)
Posted: Wed Aug 17, 2005 3:34 pm
Ride: BA Falcon EGas
Just measure them using your ones that are too long and mark it off. Then use that as you're measurement.
It'll differ a bit from one personn to the next but to give you an idea, I've go my RCAs running to the "high part" of the boot and they're 5m long.
Hope that helps a little bit.
Also, I take it that you have a sedan.
BA Falcon Futura on EGas. Stock as...
EF 5 speed manual; PH 4480 Pacemaker Headers; 2 1/2" Lukey Mandrel Bent System; Hi Flow Walker Cat; Stage 3 Crow Cam; ChipTorque Chip; 3" Mandrel Bent Intake; K&N Pod Filter; Low Pedders Suspension; 17" EL GT Champagne Rims; RPM Series Clutch
Posted: Wed Aug 17, 2005 3:39 pm
yep sedan - good idea on measuring up (now i feel dum - so obvious) :oops:
Posted: Wed Aug 17, 2005 7:39 pm
don't worry mate....i've done many things the hard way then realised s**t...that could've been easier.
Posted: Wed Aug 17, 2005 11:09 pm
Ride: EL TURBO GHIA
Power: 372 rwkw
yeah i run the sets of them and i hate it to many bloddy cables ,mine all run behind headunit under carpet around computer down under the plastc sills things beside rear seat under seat up throught carpet abd onto amps and then one set goes to the very rear right hand side and isnt long enuf by about 15 cm so i bought a 1.5 m set and cut them and solder new plugs onto the ends works a treat
HMMMM BOOST !!!
ED fairmont R.I.P
STREET FORDS FEATURE CAR ISSUE 42
Posted: Wed Aug 17, 2005 11:23 pm
Gallery: 12 images
Ride: 1994 ED XR8 Sprint
6m long gets from HU. along the passenger side sill and into boot with a metre or so left over
Banned
It is currently Sat Jul 12, 2025 9:07 am All times are UTC + 11 hours
