how good is the standard amp?
Page 1 of 1 [ 10 posts ]
 Post subject: how good is the standard amp?
Posted: Wed Oct 05, 2005 6:17 pm
I have a sony 12" sub out of my ed that ran off a 4 channel sony amp, my question is can a stock EL ghia amp run this sub?.
" If you aint first, Your last!"
Posted: Wed Oct 05, 2005 7:23 pm
Ride: Lancer Coupe
i heard that the standard amp only puts out 100wrms, either that or the cabling can only take 100wrms, but i may be wrong.
But if i were you i would get a new amp as the stock one only ran an 8" sub which would require heaps less power than a 12"
Posted: Wed Oct 05, 2005 7:43 pm
Fordmods Audio and Turbo Expert
Ride: FG Turbo Territoty Ghia
Standard amp is around 100rms from all accounts. It will run it fine but dont expect earth shattering bass.
If anything driving a 12" is better than an 8" as it will most likely have a higher sensitivity and produce more output for the same power .
Pro Class
1st Super Tech - Summernats 2007
Australian SQ Champion - Am Show 2004
Australian SQ Champion – Pro Show 2006 & Best of Show
Ford Champion - Melbourne 2004 & 2006
451.5wkw - now SOLD
 Post subject: Re: how good is the standard amp?
Posted: Thu Oct 06, 2005 4:08 pm
Ride: Kia Rio - 1.4L Auto
Power: 238 rwkw
Run an 8 gauge power cable and earth cable for the poor amp. Alot of its power is restricted due to the pissy size of the factory cabling.
As Pyro said, dont expect anything earth shattering, but for a $20 investment you will get closer to the 140 - 150WRMS figure from the factory amp.
Posted: Thu Oct 06, 2005 4:27 pm
Ride: Falcon EB-s
isnt the original sub a 6ohm?
Posted: Thu Oct 06, 2005 11:30 pm
Gallery: 9 images
Ride: Da Maverick & xe ute
nah the speakers are six ohm wired up in some freaky pattern. im not to sure but i dont think the amp is six
Posted: Thu Oct 06, 2005 11:48 pm
Power: 238 rwkw
The sub is a 6 ohm...
But the speakers are 4 ohm.
Posted: Fri Oct 07, 2005 1:49 am
Ride: 2009 FG XR6 Sedan
The amp will handle 4 ohm and yes the factory sub is 6 to reduce the amount of sub. basically the lower the ohmage of the driver the more power that will be produced but at a cost, the amp has to be of better quality especially running under 4 ohm. running under 4 ohm also produces more heat in the amp due to more load.
Posted: Fri Oct 07, 2005 2:16 am
Ride: Trik'd up EFII XR6
or maybe time to upgrade to a cheap mono block or decent multi channel amp...and sorry I know thats not what the original post was about :wink:
For Sale: 25 Farad Rockford Fosgate Competition Series Carbon Cap, more to come - pm me if interested
Posted: Mon Oct 10, 2005 8:29 pm
so basicly i may aswell stick the sony amp in and get rid of the original, thanks guys for your help.
It is currently Mon May 19, 2025 2:28 am All times are UTC + 11 hours
