mongrelmadness |
hi i was just wondering where the best place would be to earth your amp in an EL Fairmont. thanks
Tomek |
Big Kev |
{USERNAME} wrote: http://www.fordmods.com/forums/viewtopic.php?t=22790
Have a look in there i reckon no one looks when they come on here....mods should make a massive flashing search button above every forum ![]()
Tomek |
or they should make this icon, would be much easier
joolz |
If anyone has forgotten the whole chassis is earth/ground on a car unless its positive earth. Basically groung the negative as close as possible to the amp with a secure fixture to a solid part of chassis steel.
Big Kev |
{USERNAME} wrote: If anyone has forgotten the whole chassis is earth/ground on a car unless its positive earth. Basically groung the negative as close as possible to the amp with a secure fixture to a solid part of chassis steel.
thats right get a proper earth mount make sure its filed away so only bare metal is under the earth mount and make sure you use the same size cabling for the earth connection as the amps power connection. You dont have to have it as close to the amp as possible but it will be safer and more efficient if it is ... but you dont want the earth cable to be longer that than amp power cable.
mswyld |
MAKE SURE THE EARTH WIRES ARE THE SAME AS THE POWER WIRES AND THAT THE EARTH POSITION IS FREE FROM ANY PAINT OR DIRT!
