AU BOOT WILL NOT OPEN
Page 1 of 1 [ 8 posts ]
 Post subject: AU BOOT WILL NOT OPEN
Posted: Fri Feb 24, 2006 3:44 pm
HI ALL I HAVE A PROBLEM MY SMART SHIELD THE REMOTE WILL NOT OPEN THE BOOT THE HAZARD LIGHTS FLASH SO THE SIGNAL IS GETTING THERE BUT THE MOTOR WILL NOT WORK I CAN OPEN IT FROM INSIDE THE BOOT OK
ANY SUGESTIONS?
Posted: Fri Feb 24, 2006 4:04 pm
Gallery: 13 images
Ride: EF 5 Speed, XH Uterus :P
Some punctuation might help! I guess that you mean the button in the car doesn't work either?
Maloo - Holden's word for ugly.
 Post subject: boot want open
Posted: Fri Feb 24, 2006 4:10 pm
No the button inside the car doesn't work either.
sorry i failed english.
Posted: Fri Feb 24, 2006 5:03 pm
Gallery: 13 images
just check fuses, give the dash above your left knee when sitting in the drivers seat a bit of a hit - that's where the BEM (Body Electrics Module) lives. if the trigger wire has come loose, it won't let you open the boot. could also be a bad connection inside the BEM itself.
Forgot to ask - does it open by key?
Posted: Fri Feb 24, 2006 7:26 pm
check the linkage from the actuator to the look mechanism. same thing happened on a vt we had in the other day.
Posted: Fri Feb 24, 2006 9:15 pm
no key hole on this model
Posted: Fri Feb 24, 2006 10:18 pm
Ride: 2007
If the actuator is faulty or the linkage disconnected, and you can't access the lock from the rear seat all is not lost. A trick posted here before is if there is no other option then go to a wrecker or car yard and checkout the linkage position. Then remove your number plate and drill a hole so you can access the linkage and pop it from there. Then get a rubber bung to plug the hole and keep the water out.
TW.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Sun Feb 26, 2006 6:21 pm
Ride: AUII XR8
cant u open it from inside the boot?
It is currently Sat May 17, 2025 7:26 pm All times are UTC + 11 hours
