mew head unit to el
Page 1 of 1 [ 5 posts ]
 Post subject: mew head unit to el
Posted: Tue Nov 07, 2006 9:59 pm
Hi
I have just upgraded my trusty XF for an EL and
I have a basic Pioneer Mp3 /cd player 1 Year old to replace the original unit.
is there any way when wiring this up that the power on for 1 hour with no key feature in the original system can be incorperated to the Pioneer unit or is this part of the body contro unit
Does one of those wiring kits do the job Iam not after high power etc just want cd /mp3
Posted: Tue Nov 07, 2006 10:06 pm
Ride: EF OPT20
The timer feature is not BEM controlled - it's done within the original head unit.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Posted: Tue Nov 07, 2006 10:48 pm
Yes, unless you can wire it up to power on using the constant 12V, but that could cause a shorter battery life.
Posted: Wed Nov 08, 2006 7:49 am
Ride: Trik'd up EFII XR6
Hes not asking to be able to run the new Headunit continously but to use the power off after 60min function incorporated to the standard decks....
As far as I know you cant as its a circuit on the standard HU system board...you could get a timer relay so that when the ignition/acc is off the circuit will run and auto cut off after 60mins or wat ever you like....shouldnt be a problem....
For Sale: 25 Farad Rockford Fosgate Competition Series Carbon Cap, more to come - pm me if interested
Posted: Wed Nov 08, 2006 5:57 pm
Oh right, I see now.
Basically it is, as has been said, a neat trick that the stock headunits have as a feature whereby they run for an hour off constant 12V and then power down until switched power is fed through and resets the timer.
Clever, but no, it's not anything to do with the car, just the head unit.
It is currently Tue Jul 08, 2025 6:35 pm All times are UTC + 11 hours
