Powering radio outside of car
Page 1 of 3 [ 35 posts ] Go to page 1, 2, 3  Next
 Post subject: Powering radio outside of car
Posted: Sat Sep 30, 2006 10:28 pm
Hi guys, I have the FMS Stereo out of an EL GLi on my table here, and I was wondering whether I am able to power it up (and turn it on) with my bench power supply, and if so, what voltages are required and where?
Thanks in advance!
Posted: Sat Sep 30, 2006 10:31 pm
Ride: Falcon EB-s
Just need twelve volts going to the accessory wire and to the power wire, and the negative running to earth
Posted: Sat Sep 30, 2006 11:20 pm
I think I have found the two positive power connections, but I cannot locate the ground signal as per the tech documents on here?
Posted: Sat Sep 30, 2006 11:36 pm
Ride: Falcon EB-s
try black :P
Posted: Sat Sep 30, 2006 11:42 pm
Gallery: 28 images
Ride: NC II Fairlane
yellow = constant, red = switched, black = negative.
connect the yellow and red to the positive of a battery charger and the black to the negative
Prendre soin de sa sante {DESCRIPTION} vente libre en France
Posted: Sat Sep 30, 2006 11:49 pm
Hehe, yeah, I have black wire, but all of the pins on the back of the stereo are the same colour. :P
I'm not sure how accurate I have it, but I have put it as follows:
(Red is the two 12V wires, black is the ground signal)
Thanks for your help so far!
Posted: Sat Sep 30, 2006 11:54 pm
Gallery: 28 images
yeah pretty much how it is, if you have it wrong it wont switch on
Posted: Sat Sep 30, 2006 11:57 pm
Hrm, when I put it like that the deck stays off. :?
Posted: Sat Sep 30, 2006 11:58 pm
Gallery: 28 images
have u got access to factory loom? you can work out what one power ect is on there. you WILL need both postives hooked up
Posted: Sun Oct 01, 2006 12:06 am
Unfortunately I don't have access to a loom, just the stereo and my PSU. This should work. Might try and put a load on the PSU and see if it makes a differences.
Posted: Sun Oct 01, 2006 7:16 pm
Ride: BA XR6 5sp
Try the casing, it should be ground...
(yay, 1st post... love this forum...)
Posted: Sun Oct 01, 2006 9:32 pm
Hey man, welcome! I joined a while back but only recently started using the forums!
I did try the casing actually, especially the little tab with the hole in it designed for gronding but was still unsuccessful!
I dunno, it's playing hard-a** with me for some reason!
Posted: Sun Oct 01, 2006 9:37 pm
Ride: BA XR6 5sp
I've had a similar problem, mine wouldnt turn on without 12v on the memory (constant 12v) wire... (but that was with a cheap headunit in my last car... Ultravox or something...)
Posted: Sun Oct 01, 2006 9:40 pm
Yeah, I am powering both the constant and the switching power (I think, I'll be stuffed if I know what pin is what, they aren't numbered :P) but it won't fire. The earthing of the chassis is good (as I accidentally found out :P) and my supply is good and clean, 12.15V.
Posted: Sun Oct 01, 2006 9:51 pm
Ride: BA XR6 5sp
Although this is for Mazda MX5s... The 1st one looks like what you descibe... you would hate to pump 12v into something thats not power... like the output of an audio amp.. but if all fails... you may aswell try the pins that site indicates.... :P :P
It is currently Thu Jul 10, 2025 5:33 pm All times are UTC + 11 hours
