revcore |
I'm thinking about fitting an electric aerial to my ED sedan. I bought the ED Ghia aerial dash switch. There is a plug and wires behind the blank panel. I'm wondering if the wiring is for an electric aerial? If so, Would it be a case of just fitting the aerial and switch then it will work?
Also, Would a EF-EL electric aerial also fit the ED?
braidy |
Have a look in the Technical Documents.
_________________ RIP Chelsea |
snap0964 |
{USERNAME} wrote: I'm thinking about fitting an electric aerial to my ED sedan. I bought the ED Ghia aerial dash switch. There is a plug and wires behind the blank panel. I'm wondering if the wiring is for an electric aerial? If so, Would it be a case of just fitting the aerial and switch then it will work? http://www.fordmods.com/forums/documents.php?doc=69
Also, Would a EF-EL electric aerial also fit the ED? The wiring will most likely be for the clock. You will need to fit an EB/ED (possibly EA) fairmont BEM. To fit the EF/EL unit, you may need to customise the upper antenna attachment point.
