mr_rx7_ |
Age: 38 Posts: 347 Joined: 10th Jan 2005 Ride: 2002 Mustang Cobra Location: Broadmeadows (Melb. North) |
Guys, would it be hard to remove the factory GLi headunit and install one of these to the factory speakers?
http://cgi.ebay.com.au/7-Touch-Screen-B ... dZViewItem
_________________ Red 2002 Mustang Cobra |
Johnny C |
dude, so easy. pretty much just cut and shut everything from old to new. all the wiring is clearly listed. any probs.. i'll be working.. ask phong.. he knows all. so i hear
Shum's EL |
easy.. take the stock unit out and it will have a bracket on each side.. take them off and put them on the new unit.. connect all wiring and your away
Steady ED |
You'll have to mount it sticking out a bit, so the headunit clears the bulge above it when it flips out.
Get one of those adaptor plugs from supercheap, that go from ford plug to bare wires, so you don't have to chop your factory plug off.
mr_rx7_ |
Ok great.. another question.. I wont need an amp will I? Sorry got no clue about car audio..
Shum's EL |
you wont need an amp if your just installing the head unit
Busso |
don't forget about the ford factory anti theft screws that you need special screwdriver attachments for, for more info check the tech document section
_________________ 84 XF Falcon S Pak, 250 crossflow (rebuilt ~5000km ago, carby model), Bored out 30 thou, Crow racing cam, extractors, yokohama 245's all the way round, chrome 12 slotters, lowered, 4spd man, open wheeler (blew my lsd...), Thumping sound system, L.E.D's everywhere |
twr7cx |
Might also wanna read some of the threads on the el cheepo eBay.com.au DVD/LCDs/etc. if you havn't already.
mr_rx7_ |
One more thing.. I have to ground the Brake Sensor wire... can I use the same ground point as the black ground wire? (which would be the ground from the factory headunit)
Shum's EL |
{USERNAME} wrote: One more thing.. I have to ground the Brake Sensor wire... can I use the same ground point as the black ground wire? (which would be the ground from the factory headunit)
yeah thats fine.. |
twr7cx |
{USERNAME} wrote: {USERNAME} wrote: One more thing.. I have to ground the Brake Sensor wire... can I use the same ground point as the black ground wire? (which would be the ground from the factory headunit) yeah thats fine.. Yeah, provided you don't want it to operate with the rbake. |
