High beam problems
 Post subject: High beam problems
Posted: Tue Jan 22, 2008 10:49 pm
Hi everyone, i have a strange problem with my high beam on my EL Falcon. I have a pair of narva driving lights which are locating in the radiator intake on the front bumper and what happens is they flash on and off as well as the high beam lights several times after about 20-30 seconds. The driving lights are connected to the high beam wire in the headlight itself. I have replaced the relay for the high beam light and the narva relay for the driving lights and they still do it. Also the earth is bolted on tight so i can rule out that and the wiring is secure. Can anyone tell me why the problem is as all i can think of now is the combination switch at this stage.
Posted: Tue Jan 22, 2008 10:53 pm
by the way i have had these lights installed by Autobarn at least 5 yrs ago so these problems have occurred recently
Posted: Sat Jan 26, 2008 7:31 pm
For everyone out there the problem is fixed. If anyone else has this problem about flickering high beam it was the circuit breaker located under the surge tank causing the lights to flicker. Replaced it and no more :D
It is currently Mon May 19, 2025 6:20 am All times are UTC + 11 hours
