Removing EL Ghia Prem. Head Unit and Stacker Wiring?
Page 1 of 1 [ 7 posts ]
 Post subject: Removing EL Ghia Prem. Head Unit and Stacker Wiring?
Posted: Fri Jun 06, 2008 8:45 am
Guys.
Im about to pull the Premium Sound from my EL, and want to remove the stacker wiring as well so It can be sold (with the stacker).
The question is, can it be done easily? - I dont want to remove the Amp Wiring as I will be using it with the next deck.
Thanks
Nigel
Posted: Fri Jun 06, 2008 8:33 pm
Ride: xr6
In a word, no it is not easily removed espcially the head unit wiring as it is integral to the harness, the stacker wiring would be marginally easier but still a reasonably big job.....
Do it once, Do it right!!!!!!
Posted: Tue Jun 10, 2008 12:02 pm
Im not removing the Head Unit Wiring.. just the stacker control wiring. The rest is just amp control.... and I want that for my new one.
Nigel
Posted: Wed Jun 11, 2008 2:07 pm
Ride: falcon
the stacker and amp cable is a pain to remove.
From memory the stacker cable runs passenger side dash, there is little access and alot of mucking around. The amp cable runs underneath the centre console, across the front drivers seats and again because limited space it is a troublesome to remove without chopping it.
doing it in reverse with a fwd is like being fuked by a fat man and saying "well he has tits so i'm not gay"
 Post subject: Re: Removing EL Ghia Prem. Head Unit and Stacker Wiring?
Posted: Wed Jun 11, 2008 3:58 pm
Ride: Kia Rio - 1.4L Auto
Power: 238 rwkw
Guys.
Thanks
Nigel
Piss off the amp cable as well. It has a proprietry plug at the head unit end that is useless with anytihng else.
To get both the cables out, its pretty much an interior out job. Front seats, rear base, console and carpet.
Posted: Sun Jun 15, 2008 1:19 am
Ride: xr6
As I said, big job....
Posted: Mon Jun 23, 2008 12:49 pm
Ride: Drives Like Fun
Power: 318 rwkw
Location: Melbourne Interior: Cappucino Exterior: Sparkling Burgundy
It's not a big job - doesn't take as long as you think.
It is currently Sat May 17, 2025 10:45 pm All times are UTC + 11 hours
