What channel amp?
Page 1 of 1 [ 13 posts ]
 Post subject: What channel amp?
Posted: Mon Nov 03, 2008 8:02 pm
Ride: EF Fairmont II
I got myself a 10" kicker sub off a mate.
Her car got written off and she only took the sub not the amp so my question is what amp would i need to power the sub? 4 or 6 channel?
I have all stock ford pioneer speakers and a pioneer hu if thats helps
cheers
Posted: Mon Nov 03, 2008 9:13 pm
Ride: eb xr6 and EL Falcon
if you wanted all four pioneers plus the sub amped you would need a 6 channell amp but if you only wanted the front two speakers and the sub amped, a four channell would do the trick and then you would run the rears off the head unit and as they are only the stock pioneer speakers, you would have no trouble at all running them off the head unit :)
Posted: Mon Nov 03, 2008 9:20 pm
Ride: xr6
No you don't NEED a 6 ch amp you will need 5 channels 1 for each speaker and 1 for the sub, a 6ch will do the job or you can get a 4ch and a mono or a 4 ch and a 2ch bridged for the sub depends on the budget....
Do it once, Do it right!!!!!!
Posted: Mon Nov 03, 2008 9:24 pm
Ride: Trik'd up EFII XR6
As outlaw said, or even if your on a reallly tight budget just run the stock splits off the headunit and get a semi-decent monoblock or 2 channel (that you can run bridged) to power the sub
For Sale: 25 Farad Rockford Fosgate Competition Series Carbon Cap, more to come - pm me if interested
Posted: Mon Nov 03, 2008 9:54 pm
I think il go the 5 channel amp way?
Posted: Mon Nov 03, 2008 10:02 pm
Would amping the stock speakers be of much benefit anyways? I'm pretty sure they blow under the output any after market head unit, let alone amped... Your best bet would be to pick up a 4 channel amp and some half decent spilts, run them off 2 channels, bridge the other 2 with a LPF for the sub, and leave the rears connected to the head unit...
Posted: Mon Nov 03, 2008 10:07 pm
ACT Cruise Moderator
Ride: '06 BF GT-P
Power: 293 rwkw
Budget for some new speakers then. The stock one's won't last long with real power being fed in.
Posted: Tue Nov 04, 2008 1:44 pm
Ok plan is to get new speakers front and rear. Would it be better to get some pioneer speakers as my new hu is pioneer or it dosnt matter ?
Posted: Tue Nov 04, 2008 4:08 pm
Ride: '06 BF GT-P
Power: 293 rwkw
Doesn't matter. Listen to a bunch in your price range. Be sure to take a CD you like along, and make sure they're not doing any funny stuff in the display head unit (weird EQ to cover up problems for example).
Then pick the ones you like best.
Posted: Tue Nov 04, 2008 5:16 pm
Ok thanks data mine, really appreciate your help.
Posted: Tue Nov 04, 2008 6:38 pm
Ride: xr6
As data_mine says take a disc that you like especially if it is a bit stressful for speakers and make sure that they set everything to "flat" and no sub, get them to show you that they are set to flat don't take their word for it and no you don't need to get Pioneer speakers, you don't even need to get the same brand front and rear...
Posted: Wed Nov 05, 2008 7:57 pm
Ride: 2009 FG XR6 Sedan
Dont waiste your money on rears. Spend it on the fronts only as they are the main speakers, the rears are only a fill. Alot of decent systems hardly use rears at all. Mine is faded to about 80% front and 20% rear.
Posted: Thu Nov 06, 2008 1:34 pm
Ride: xr6
True, I myself have not run rears at all in about 14yrs...
It is currently Sun May 18, 2025 11:21 pm All times are UTC + 11 hours
