alpine gear
Page 1 of 1 [ 7 posts ]
 Post subject: alpine gear
Posted: Thu Dec 25, 2008 6:23 pm
Ride: EF Fairmont
i bought a alpine type s 12inch sub 900w and an mrp-m500 mono block i have to admit it is quite a bit under what i exspected just want others opinions on this
Posted: Thu Dec 25, 2008 7:22 pm
Ride: EF wagoon
i run a type r 12' and a 300w rms monoblock pioneer amp and it seems to work ok.
EF GLi Wagoon
Grandpa Spec
Posted: Fri Dec 26, 2008 2:27 pm
Gallery: 16 images
Ride: BA
My first sound system was 12" type R with 360w RMS, was a decent volume and depth. Got 2 x 12" type R's with 500w RMS each, which is obviously excessively loud :P.
But the one sub was good. What cabling you using for the sub?
Silver 2003 BA XT - 2 ported 12" Alpine type R subs, 5 by 7 Alpine type R rears, 5 and half inch Alpine splits up front, Alpine head unit.
Blue dome and footwell neons. Debadged and deaerialed. Custom front grill.
Wheels and lowering to come next, then exhaust.
Posted: Fri Dec 26, 2008 2:57 pm
Ride: EBII
Make sure the gain isn't turned way down on the amp
Brand New Distributor: $50 + other stuffs
forums/viewtopic.php?t=73696&highlight=ebii
... "And the mountains shall drop sweet wine and the hills shall melt"...
Posted: Fri Dec 26, 2008 6:39 pm
Ride: EF Fairmont
na the amp is maxed out, the cabling isnt too bad relitivly good quality to be honest but yes it does go fairly hard but i would of exspected more for 750$ worth but i didnt end up paying that much anyway
Posted: Fri Dec 26, 2008 7:29 pm
Ride: EF Fairmont Sedan
Power: 180 rwkw
Have you wired it up properly?
Have you got the Dual 2ohm Alpine Type S 12" Subs
or the Dual 4ohm Alpine Type S's 12" Subs
How Big is your Sub Box - has it any air leaks
PROEF 13.46 @ 105.78mph - 1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
Stock Fuel Pump, 29lb Injectors, JMM Street Series Headers, 2.5" Exhaust, 205rwkw
Posted: Fri Dec 26, 2008 8:28 pm
Ride: EF Fairmont
duel 4 ohms nd the box appears to be ok
and all the wiring is pretty straight forward
It is currently Thu Jul 10, 2025 10:18 pm All times are UTC + 11 hours
