DrGore |
How do i remove the headunit out of my car?
EFNA |
beside the ashtray should be 2 screw either side, take them out should open like a hinge on the top.. pull it off and it will reveal the headunit and most likely have torx screws holding it in, this is were a torx bits come handy...once undone the head unit should slide out... hope this helps
_________________ AU FAIRMONT GHIA: 5.0 Dealer ordered SVO mods ( seeking clarification ATM), tickford suspension. |
graham_h |
you'll need the "security" type torx bits as the screw has a pin in the middle
XRfairmont67 |
if u cant find tamper(security) proof torx bits, u can sometimes get away with a smallish flat blade screwdriver.
SLO247 |
Or do what I have done with all of them. Use a normal torx bit, and bash it into the screw while you brace the bracket from behind with a long flathead. It works...
graham_h |
fortunately a mate had a set, came out easy as
now to install the pioneer ! |
EFNA |
there only $20 from supercheap...
