clampy |
finnally got all my system up and going i got 6s in the front and rear 12 in the boot and 2 amps but i have some 6*9s i wanna put in... just dont know where i want em.... some where , were its not gunna take long to put them in and its gunna be easy any ideas?????
i was thinking in boxes in the boot.......
_________________ EL Futura 5 speed factory:PH47FL goneeeee |
SVD115 |
the bin, 6x9's are crap, especially once you have a sub, they run basically the same freq ranges and tend to cancel each other out, 6x9's are really only good if you dont wanna run a sub IMO.
clampy |
ok as i was saying where can i put them...... IN MY CAR
data_mine |
Agreed, get rid of the 6x9s they're no good for you.
Sell them, bin them, whatever. Don't waste your time installing them. The 6x9 encroaches on 10" sub territory, and the oval speakers don't sound as good as round ones. The ONLY use for them, is profiteering for salesmen at JB/Strathfield etc.
clampy |
they sound ok to me sound better then the 6s so the boot it is......
kwaussiekid |
IMHO, 6x9's belong on the parcel shelf, with the high frequency pass filter off so it blocks bass sounds, and give a mellow crisp sound to fill the rear of your cabin.
_________________ The older I get the better I was! |
parrotscaraudio |
{USERNAME} wrote: finnally got all my system up and going i got 6s in the front and rear 12 in the boot and 2 amps but i have some 6*9s i wanna put in... just dont know where i want em.... some where , were its not gunna take long to put them in and its gunna be easy any ideas????? i was thinking in boxes in the boot....... 6x9s dont run the same freq as subs as a 6x9 cant go as low as 20 hrtz Every day purchased 6x9s go as low as 40 hrtz and as high as 2500 hrtz a sub usaly only goes as high as 500 hrtz 6x9s are great with subs as yuou can tune your amp to run them higher than 150 hrtz which will allow you to run your sub at optimum efficiency Subs only clash with 6x9s when the tuning is up the crapper and tuned by a cowboy What is your car so as to tell you the best place to mount you speakers Parrot 22 years in car audio instalation http://www.rlsnell.20m.com http://www.autowreck.com.au http://z3.invisionfree.com/APV/index.php? http://www.youtube.com/user/parrotscaraudio
jvangent |
6x9 are good to use in my opinion. I have installed mine on the parcel shelf and I must admit I had to set the frequencies a little higher for the back im thinking because the subs drown out the highs out a bit more. (if you know what I mean) but I would recommend putting them on the back shelf. Or if you want to be a little tricky maybe in the frond door area….. but I have mine in the back and the seem to be ok. I hope this helps abit.
jvangent |
