Two subs one channel
Page 1 of 1 [ 9 posts ]
 Post subject: Two subs one channel
Posted: Sun May 22, 2005 6:20 pm
Ride: No Fords current
Anyone know why anyone would do this?
They've got the 2 channel amp, bridged it and then connected two subs up in series. So positive of amp to pos of sub 1, neg of sub 1 to pos of sub 2, neg of sub 2 to neg on amp.
Posted: Sun May 22, 2005 6:37 pm
ACT Cruise Moderator
Ride: '06 BF GT-P
Power: 293 rwkw
should've wried the subs in parallel unbless of course the amp sucks and can't handle the low impedance.
Posted: Sun May 22, 2005 6:51 pm
it's some rockford fosgate punch amp. basically mate bought the car, crashed it, and i stole the sound system, this wasa couple of months ago and i was just wondering about it then. the previous owner really liked there rockford stuff.
Posted: Sun May 22, 2005 7:48 pm
Ride: BF Typhoon
what type of subs?
BF Typhoon, Dejavu - 6sp Auto, Leather, Sunroof, 19"s, Electric Pedals, Tint, FPV Sports Wheel, FPV Mats.
Posted: Sun May 22, 2005 8:24 pm
Gallery: 12 images
Ride: 1994 ED XR8 Sprint
the biggest reason i can think of is that the subs share a common chamber, and as such require the same signal, amount of power, etc
bridging the 2 channel amp turns it into a mono output, meaning it's impossible to get a difference between 2 channels that would affect performance
Banned
Posted: Sun May 22, 2005 9:29 pm
You'd still get all that wiring in parallel on the brdiged channel. What's the differences in parrellel and series?
It's a Rockford Fosgate Punch series amp and two of the same RF Punch series subs.
Posted: Sun May 22, 2005 9:59 pm
Ride: ED
who knows, the amp i got can't bridge it self so i just connect left neg to left pos and visversa on the right
Posted: Sun May 22, 2005 10:00 pm
Ride: '06 BF GT-P
Power: 293 rwkw
parallel halves (for two subs) the impedence of the subs, allowing the amp to deliver more power.
eg. you have two 4Ohm subs, and a amp capable of driving loads at 2 or 4 Ohms.
In series you present the amp with 4+4=8Ohms the amp will struggle or not work at all.
In parallel you present the amp with (4*4)/(4+4) = 2Ohm.
Now for power calculations you need to know the voltage output of the amp (we'll guess 70V here), and the impedance of the load (the subs).
For series: 70V / 8Ohm = 8.75A (current) which 8.75 * 70V to get power = 612Watts
For parallel: 70V / 2Ohm = 35A which 35 * 70 = 2450Watts.
These numbers a guesses, and amps/subs aren't perfect so the numbers will be different, but the idea is there. The amp can drive a 2Ohm load harder than an 8Ohm or 4 Ohm load (as long as the amp is "2Ohm Stable").
Posted: Mon May 23, 2005 12:33 am
Fordmods Audio and Turbo Expert
Ride: FG Turbo Territoty Ghia
It depends on a number of factors.
Most class A/B amps dont bride down and run a 2ohm load so you can wire them for an 8ohm load and the amp will have no problems driving them (although you will get reduced power at higher impedences).
The other possibility is that the subs are 2ohm subs (or dual voice coil 4ohms) and wiring that way will provide a 4ohm load.
Pro Class
1st Super Tech - Summernats 2007
Australian SQ Champion - Am Show 2004
Australian SQ Champion – Pro Show 2006 & Best of Show
Ford Champion - Melbourne 2004 & 2006
451.5wkw - now SOLD
It is currently Thu Jul 10, 2025 1:32 am All times are UTC + 11 hours
