AMP WIRING - 4 channels into 1
Page 1 of 1 [ 5 posts ]
 Post subject: AMP WIRING - 4 channels into 1
Posted: Wed Sep 15, 2010 3:19 pm
Ride: 97 EL XR6
Power: 162 rwkw
To put it simply, will a setup like the one ive drawn work?
one rca split into 2, one feeding front, one feeding rear
then bridging the 2 channels together at the other end as i have drawn
my logic is that the same signal is going into each channel, therefore same output from each channel, so really im using 2 channels to power one sub.
It sounds ok in MY head, but i am no expert with car audio :lol:
07 BF MKII XR6T
310rwkw @ 13psi - Tuned By CMS
 Post subject: Re: AMP WIRING - 4 channels into 1
Posted: Wed Sep 15, 2010 8:09 pm
Gallery: 12 images
Ride: Fairmont Ghia BA 5.4L V8, AU 6
Power: 205 rwkw
What is the amp you got mate? only certian AMP's can go from 4/2/1 channel.
Chaos, Panic and Disorder. My work here is finally done.
BA Fairmont Ghia 5.4L. Mods -Full Exhaust, Chipped, Custom Intake, CAI @205.4RWKW.
Stezza - Alpine Type R Splits & 6x9's, Alpine 400w RMS 4ch, 380w RMS Pioneer Mono, 2x12" Pioneer Subs and an AVH-P5950DVD Player.
Posted: Thu Sep 16, 2010 12:13 am
ACT Cruise Moderator
Ride: '06 BF GT-P
Power: 293 rwkw
In short, no that won't work.
As you say you're feeding the same signal into two channels, therefore the outputs will be the same = sub not moving (best case), smoke being released (worst case)
Most amps (99.99999% of them) won't work like that.
Posted: Thu Sep 16, 2010 11:13 pm
Ride: Mazda CX-5 & 96 EL Falcon
as its been said, some amps can do the 4/2/1 but not all, check the amps manual, some websites have old manuals on them.
best option (if the amp supports it) is to do what I've done, run the two RCA's into the rear channels (3 and 4) then hook the positive of the sub to the positive of channel 3 and the negative to the negative of channel 4.
This will only work if the amp is bridgeable and internally at that, otherwise look up bridging on google and see what you can find.
Also as I said CHECK THE MANUAL or even the amp casing and see if it can be done, otherwise you will more than likely have a nice smoke show of your amp going bang.
Posted: Fri Sep 17, 2010 9:21 am
Ride: 97 EL XR6
Power: 162 rwkw
its definately a 4/3/2 channel amp, i dont think i going to try it anyway, not worth the risk. but i thought it may be possible to feed to seperate channels to one sub.
like running 2 RCAs from the same signal into 2 diferent mono block amps, and then powering a single sub with both amps....
07 BF MKII XR6T
It is currently Wed May 21, 2025 10:02 pm All times are UTC + 11 hours
