Mods for a Ford Capri ??
Page 1 of 1 [ 12 posts ]
 Post subject: Mods for a Ford Capri ??
Posted: Fri May 02, 2008 3:31 am
Ride: laner :(
hey guys just wondering if anyone knows of modification packages for the ford capri ( turbo or non turbo ) im talking like the dev mods like you get from jmm motors for the 4.ltr 6cyl.
something that will boost the power without adding turbo/supercharger.
any sites you know of lemme know :D
or any mod packs you know of for a mazda mx5 let me know aswell :)
thanks very much
adam
Posted: Fri May 02, 2008 9:43 am
Gallery: 21 images
Ride: 98 EL Futura
Power: 199 rwkw
Give SVO in Ringwood a call, i'v seen a few Ford Capri's with SVO badges on them so im guessing they have worked on them before.
EL Futura: CVE head, Wolf V500, ICE Ignition and Coil, 36lb injectors, Walbro 255lb, Paci comps, 3" exhaust, T5, Harrop Truetrac with 3.9s. Now with 198.9rwkw, (~185rwkw and 13.80 @99.1mph) with more power to come
Posted: Fri May 02, 2008 9:50 am
isnt the common mod to drop a V8 between the rails for the Capri's?
be alot more beneficial than wasting money on a four
Edit: ok i assume were not talking about the old classic capri..... forget what i said
Posted: Wed May 07, 2008 11:55 pm
best mod for a late model capri......sell it to a hair dresser and buy a MK1 capri GT V6.
Posted: Thu May 08, 2008 12:45 am
Ride: ef xr8
Power: 229 rwkw
Maybe an engine conversion off a MX6/telstar .
Its easy as pie puting a turbo or supercharger on a little 4 cylinder.
id be looking at a cheap blower.
http://cgi.ebay.com.au/Toyota-SC14-Supe ... dZViewItem
or maybe buying a cheap t25 turbo, a "j" pipe into it from a the cast manifold and a quick nip and tuck exhaust wise would be easy, a aftermarket ecu and all for under 2500.
Because of Beer, Thirst is a Beautiful Thing!
'95 EF XR8 auto, Advance headers, 3" exhaust, Cobra manifold, BBK 75mm throttle body , 80MM Marauder MAF, Vortech V2 T Trim , 307 rwhp, 405 ft/lb 13.2 @ 105 MPH
Now N/A (permanent Lag) - AFR 165's, Comp XE270 cam, 1.6 RR - 269 rwhp 14.1 @ 102mph.
Posted: Fri May 16, 2008 8:49 pm
Ride: 06 Teritory,mod Capri,XE falcon
Mate,i have the same problem....got a 91 Capri,1.6 DOHC non turbo.Been able to change fuel pump,injectors and rail,cold air intake,extractors,etc.Bolt on type of stuff,you know.Been trying to source cams to compare if anyone knows of suitable sites?Cheers guys.
Getting old is a fact,maturing is optional......
Posted: Sat Jul 26, 2008 7:02 pm
Ride: Ford ED GLi
i wouldnt mind what mods ya can do to a capri got one for a work car but it can always goe harder until my xr8 is back on the road :)
anyone tried like bolt on mods minus turbo's to increase some throttle response maybe even more power??
Posted: Sat Jul 26, 2008 7:08 pm
Gallery: 5 images
Ride: 2021 Amarok V6
just find a capri turbo motor and drop it in. :P apparently they were built by tickford?
Posted: Sat Jul 26, 2008 7:11 pm
Gallery: 21 images
Ride: 98 EL Futura
Power: 199 rwkw
are they the ford capri XR2's???
Posted: Sat Jul 26, 2008 7:12 pm
Gallery: 5 images
im not sure. i dont think so. i think theyre just Ford Capri Turbo.
Posted: Sat Nov 22, 2008 6:46 pm
Fordmods Addict
Ride: BA XR6T
you could get non turbo and turbo versions of the xr2 here. in the usa all xr2's were turbos.
the tickford versions were the clubsprint models, they were a limited run they did a couple of times. had unique front and rear bars, lowered tickford tuned suspension, were strictly a 2 seater instead of a 4, and had a few other bits and peices. they came as turbo and non turbo aswell.
if ur after capri info, this isnt a bad forum, though based in america:
http://www.teamcapri.com/
 Post subject: Re: Mods for a Ford Capri ??
Posted: Tue Feb 24, 2009 10:10 pm
Ride: KQ laser
I belive a B6T conversion would be the best way to go on a late capri. They share some of the same gear as the Lasers of the same era.
cron
It is currently Wed May 21, 2025 12:30 am All times are UTC + 11 hours
