EBT04Z |
Hi all,
I thought i might post up same pics of my car and abit of info. What do you think of it? Its a stock AU Falcon 6, with aT04Z turbo, Tial 44mm gate and 50mm B.O.V, 42lbs injectors with Walpro intank, 3" dump and exhaust, E.M.S 8860 and Eboost 2 . Ford C4 auto done by Dominello transmissions with 3000 stally and minispool diff. Here are the pic's ![]() At WSID for my first time with 11.99 at 106 miles ![]() ![]() ![]() Inside, ![]() Rebuilded. New motor with spool rods and CP pistons, Surecam billet cam, s/s valves, brass valve guides, converted soilded rockers, double valvesprings, pored head with head studs and main studs. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Started to get some of goodies for new fuel system, ![]() and today came my Convopro's wheels and tyres 15"x10" and 15"x4" M/T 275x50 radial, ![]() 165x80 tyres, ![]() rear's are on, ![]()
_________________ EB fairmont with std AU engine T04Z turbo, Tial 44mm gate, Tial 50mm BOV, ems 8860 |
Matt_jew |
Nice stuff.
Local ruff boy hey. Will have to catch up sometime.
KWIKXR |
Awesome EB dude!! Lots of special parts have gone into the motor, not to mention the rest of the car in general - it has heaps of potential mate. Should be good to see what your next figures down the 1/4 will be
fordfreak ef |
looks good!. nice engine mods.
11.99 at 106 mph indicates a great launch and midrange... |
ToranaGuy |
That's one serious EB Fairmont, nice dude!
Cheers ToranaGuy
Falcon_92_EB |
{USERNAME} wrote: ![]() mmmmmmmmmm....... convo pros (droool) Nice car man ![]() |
Michael (HYPOEB) |
Top work with the 11.99 on a stock bottom end! What power were you making when you ran that? Also what ECU were you running back then?
_________________ EBT-747 - |
svo_matt |
yes is a very nice box car have see it around st clair i love the colour also your old mans is one sweet car as well
_________________ ..My fake plant died because I forgot to pretend to water it.. |
EBT04Z |
{USERNAME} wrote: looks good!. nice engine mods. 11.99 at 106 mph indicates a great launch and midrange... I think i would have gone quicker but with the standard valve gear doesn't like it right up there with 3.27 final drive. Might need to go to 3.08 or even 2.92 final drive. 13 flat on low boost 10psi and 11.99 on high boost 14psi ![]() More pics with the fronts on, ![]() Needs a wash ![]()
huggiebear |
looks tough.. i like it!!! how did you go with mounting the coil pack ontop of the rocker cover? i dont seem to have enough room
fordman351 |
Is that plenum a JD Custom? Nice setup by the way
EBT04Z |
{USERNAME} wrote: looks tough.. i like it!!! how did you go with mounting the coil pack ontop of the rocker cover? i dont seem to have enough room ![]() Have no problem with bonnet clearance. Welded some aluminium plate to rocker cover first to bolt the coil on top. Home made manifolds. The old man (EBXR8380) has a Tig and Mig that comes in handy for these kind of thing.
EBT04Z |
Up graded the turbo. Do you think it's bigger enough?
![]() and a Tial 60mm wastegate. ![]() Also a pair Goodyear slicks 29/11/15. ![]() Making a new inlet manifold with a Holley 95mm throttle body.. ![]() ![]() ![]() I'm also changing my intercooler piping to Aluminium and making a new turbo manifold. Don't know if the slicks will fit, but if they don't i will make them...
ToranaGuy |
Ooooo la la, nice gear!
Cheers ToranaGuy
DA22LE |
Hey,
What are you using for the sync sensor on the 8860......I'm having some issues....... Cheers Daz
_________________ BA XR8 Boss 260 |
