need help to put eb xr8 motor into au2
Page 1 of 1 [ 14 posts ]
 Post subject: need help to put eb xr8 motor into au2
Posted: Sat Oct 02, 2010 5:29 pm
hi all just wondering has any one put a eb xr8 motor into a au 2 sedan i want to find out what main things i have to change :!: :!: :!:
 Post subject: Re: eb xr8 into au2
Posted: Sat Oct 02, 2010 5:34 pm
Power: 139 rwkw
Why would you want to?
It would be an exercise in futility. It would be a step backwards from the 6 as the EB 5.0 was not very good.
If you are doing a conversion spend the extra and get a proper AU 5.0. It will cost less in the long run.
Posted: Sun Oct 03, 2010 12:48 am
Gallery: 25 images
Heed these words. Not to mention you probably couldn't do it due to emissions rules.
ToranaGuy
 Post subject: Re: need help to put eb xr8 motor into au2
Posted: Sun Oct 03, 2010 12:58 am
Ride: ford au
whole list of modification let alone getting it to run with a Au
Also is this au a v8 or a 6 banger
Daily Driver, Series 1 Au Forte
Quote:
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
Posted: Sun Oct 03, 2010 8:11 am
my au is a 6 banger and plus i have the xr8 motor sitting there and it was a good motor when it was in the car before hand
Posted: Sun Oct 03, 2010 9:00 am
QLD Cruise Moderator
Ride: EF Ford Falcon Wagon
I agree
Posted: Sun Oct 03, 2010 9:40 am
Ride: ford au
Lot of effin work to get a 8 banger working in a 6 banger,
Emission laws dont allow it, but if you ran straight lpg probally get away with it
Then you gonna have a massive headache getting it to run on the 6 cylinder wiring and looms
Then you need to probally need a engineers certificte to get it road worthy
Might as well go and buy a xr8 car or try and find a xr8 motor from the same series and shove it in with all the v8 loom out of a sedan
Posted: Sun Oct 03, 2010 10:19 am
Ride: '96 EL Ford Fairmonth Ghia.
Sell the XR8 motor and put it towards a AU XR8 motor. More than likely the easiest option; especially with emission laws as the older engine wouldn't be as "Green" as the AU's.
Posted: Sun Oct 03, 2010 11:53 am
NSW Cruise Moderator
Gallery: 12 images
Ride: TE50
Dispose of your EB boat anchor, get AU motor, loom and ecu. plug and play the way its ment to be.
I have a car.
Posted: Sun Oct 03, 2010 2:14 pm
Ride: BA XT, NCII V8
yeah i can see both points of view,
driving round in a l6 with a good v8 sitting in the shed not doing anything,
but then again the EB 5L would prob put out less power than the AU L6 and be heavier, so not worth the effort,
if i was you i would keep the au as is and buy a EB with a dead motor in it for a few hundered bux and dump the 5ltr in it and have it as a toy,
Then if the EB packs up you still have a perfectly good AU to get a round in.
Posted: Thu Oct 07, 2010 4:43 pm
i just want to find out if any one has do the modification because i have the whole wiring loom for the xr8 motor because it was a real good motor better then the other eb xr8 motor so if any one can help it would be a big help
Posted: Thu Oct 07, 2010 7:51 pm
Ride: ford au
It wont work in the au, the above posts explain it all
Posted: Fri Oct 08, 2010 3:19 pm
is because of the emission laws or it wont fit
Posted: Fri Oct 08, 2010 3:57 pm
1. older engine in newer car has different emmision standards.
2. ecu and wiring is different due to AU using different sensors etc.
3. EB stock V8 is outdated and not as good as more modern AU V8.
It is currently Sun May 18, 2025 3:13 pm All times are UTC + 11 hours
