LATICIA'S LIMO! (sommers nl)
Page 1 of 7 [ 101 posts ] Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: LATICIA'S LIMO! (sommers nl)
Posted: Sun Dec 28, 2008 8:50 am
Ride: 98 NL, 97NL, 98EL
Power: 141 rwkw
hey guys. i thought i might start a thread on my NL, its a May 97 with leather interior, so far, what I've done to it so far is ...
Most of the work I do, is at my work, I work for a Auto/Diff/Radiator company.
All this work has been manily carried out myself .. by a chick!!! woot! hehehe
New Motor
I think its a RPD cam, it has about 4 Shims in each rocker arm
2800 highstall
3.45LSD (3.71's are coming though work)
17" Speedy Longchamp wheels
2 1/2 inch cat back system
AU Injectors
Lowered springs
EX-COP ECU
Alloy Tailshalf
Rear XR6 Spolier
Alarm (with 6 aux outs)
Truck Auto Cooler
4 6" 80W Response Speakers
6 tweeters, (all jaycar) Vifa and Repsonse
Two amps 1 1000W amp, and 1 300W amp
Sony MP3/WMA/DVD head unit.
10inch Pioneer SUB
2000W Intvertor for my caravan (32ft van)
Twin Battery system
Window Tint
25W UHF with police scanning
Now, stuff it needs
New or fix the valve body in the auto, the 1/2 soilnoid is is sticky, its not hard to do, just put it on a hoist and take off the pan, filter, remove valve body, and use a a fine 2cm brush in the soiloid housing.
Needs new ball joints,
Needs new Rotor, (i don't know what the person did to them before I got it!!!) just of always when come to a stop, kept foot on brake hard. so it shakes when I brake.
Oil Pressure sender
Headlight switch! The plastic dimmer part broke, so i found a EA one that im using for $3 from the wreckers.
hand brake adjustment.
I'll post some Photo's up soon!
Laticia ... (the working on car chick!!)
BANNED!!!!
Posted: Sun Dec 28, 2008 8:57 am
Power: 141 rwkw
Here is a photo of the car
You do not have the required permissions to view the files attached to this post.
BANNED!!!!
Gallery: 28 images
Ride: NC II Fairlane
Sounds the goods. I hope your bringing this up when you pick up the parts
Prendre soin de sa sante {DESCRIPTION} vente libre en France
Posted: Sun Dec 28, 2008 8:58 am
Power: 141 rwkw
I put a BA falcon exhaust cover on the mainfold, had to angle grind a little off, but it makes the engine bay look so much better!!
BANNED!!!!
Posted: Sun Dec 28, 2008 9:01 am
Power: 141 rwkw
Sure am :)
BANNED!!!!
Posted: Sun Dec 28, 2008 9:02 am
Power: 141 rwkw
When I put the new motor in, I put my highstall in. here is a photo of it...
BANNED!!!!
Posted: Sun Dec 28, 2008 9:09 am
Power: 141 rwkw
forgot to mention, it was dyno-ed at work, and had 141rwkw and 420nm I will scan the print out this afternoon...
Laticia!
BANNED!!!!
Posted: Sun Dec 28, 2008 9:32 am
Power: 141 rwkw
hey again, I did not like the indicator lights that used to come on with the head lights when your turning, so I've wired them up to a ACC so they are day running lights. I think it looks good with just parkers on and the bottom lights on during the day .....
BANNED!!!!
Posted: Sun Dec 28, 2008 9:33 am
Power: 141 rwkw
The mod I'm going to do today, is use my car alarm, to keep the thermos's running for 30sec's after you turn off the motor ... Does anyone know if the fans come on with a Neg or Pos power???
BANNED!!!!
Posted: Sun Dec 28, 2008 10:14 am
Nice lane!!
May i ask why you want to keep the fans running after you turn the car off?
Are you fitting a turbo or what?
I dont mean to be rude, it wouldent hurt to have the fans running for 30 seconds after you shut the car off it just normally you do it on a car with a turbo aswell as keeping the motor running to cool down the turbo
Josh
Posted: Sun Dec 28, 2008 10:39 am
Power: 141 rwkw
Thanks! I think it rocks for a chicks car!!! No stupid pink paint on it!!!
my alarm system has aux outs, that can be send power i.e. to keep healights on. to 30sec's 60sec's 90'sec when armed,
Or, if that fails me, i've got a turbo timer kit which im gonna try and make!!!
Laticia!
BANNED!!!!
Posted: Sun Dec 28, 2008 10:42 am
will just put uneccessary load on the battery
Posted: Sun Dec 28, 2008 10:54 am
Laticia!
so what you saying is your fans will turn off when the car is switched off and come on again when you arm the alarm, i agree with fordfairmont.
people might think there is a problem under there i would reconsider it
Posted: Sun Dec 28, 2008 10:58 am
Power: 141 rwkw
no no, not quite, the fans will only come on for 30secs when you turn the key off. then they turn off after 30sec's (like a turbo timer), i have another temp sensor that will only turn the fans on for 30 secs when its warm enough....
BANNED!!!!
Posted: Sun Dec 28, 2008 11:03 am
so they wont come on when you turn the key off unless the temp is over a set temp
It is currently Mon Jun 23, 2025 3:44 am All times are UTC + 11 hours
