pbdrafting |
Hi Guys
l wander if l could get some help please l just brought a 1995 ford Fairmont a day later l went to unlock the car with the remote and it would not work so l unlocked it with the key this set the alarm off so l disconnected the batter l then pulled the emobilizer fuse out and put it back in this fixed most thongs except the remote only unlocks the boot now when it should unlock the door so l have to do it manually with the key. Does anybody now how to reset the key remote so when u press the door button it unlocks the door not the boot? Regards Paul |
TedW |
new battery in remote
check fuses in under dash fuse box check fuses at alarm module do you have another remote to try reprogram remote if genuine ford -doors closed accessory position - push rear demist switch 3 times -then push any button on remote - key off possible bem problem |
pbdrafting |
Thanks for being so prompt
battery ok in remote tried demister still only opens boot on both buttons say with demister program do u leave key in ignition when u try remote (only have one by the way) also fuses ok still have to lock door manually with key any other suggestions? What about disconnecting battery again? Regards Paul |
TedW |
is it a ford remote or to suit a aftermarket alarm system - possibly post a pic of remote
have you checked fuses at alarm module does central locking lock and unlock from switch on dash procedure was for genuine ford remotes only key to accessory position and stays in.... does remote lock doors possible faulty BEM possible faulty remote possible faulty alarm module |
Users browsing this forum: No registered users and 49 guests |
