Battery size to start AU 4.0 racecar
Page 1 of 1 [ 2 posts ]
 Post subject: Battery size to start AU 4.0 racecar
Posted: Thu Feb 25, 2016 6:18 pm
Ride: AU XR8 220 Manual
Hi guys.
I am looking at light weight options for car batteries to suit my track car.
The car is a low budget AU XR6. No electrics other than the ECU and fuel system.
What have people used that saved a few kgs but didn't cost the earth?
In CCA terms what' is the minimum i would need to start the Ford 6?
Many thanks!
 Post subject: Re: Battery size to start AU 4.0 racecar
Posted: Thu Feb 25, 2016 9:47 pm
Ride: 99 Au Falcon
The lowest CCA I got my AU to start on was 350-375a. If your engine has a higher compression it will need more amps. If you need to keep weight to a low use a small 100-200cca battery to power accessory's and use a large starter battery to jump the car.
I would op to use something in the home of 200cca as if you stall on the racetrack you can start the engine but the battery will be toast after that.
I personally have no idea on what battery to use as cost>cca as I just use a 650cca supercharge for all my cars.
I may be dumb but at least i'm not a cop
Users browsing this forum: No registered users and 41 guests
It is currently Sun May 25, 2025 7:21 am All times are UTC + 11 hours
