T5 speedo signal
Page 1 of 1 [ 5 posts ]
 Post subject: T5 speedo signal
Posted: Sat Jul 27, 2013 12:03 pm
Gallery: 8 images
Ride: EL XR6
Have to work out a way to wire my speedo to the t56 .
I know the t56 speedo sender, sends out a inductive signal . So I will somehow have to convert it to what a t5 speedo sender puts out . Think it maybe sign wave ??
I've read up on a jaycar speedo corrector / ratio box . But it only says it can increase the signal . Doesn't mention if it can convert it .
Any idea what I can do. And does anyone know which wires on the t5 harness are for the t5 speedo sender ?
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
 Post subject: Re: T5 speedo signal
Posted: Sun Jul 28, 2013 12:23 am
Gallery: 8 images
Ride: EL XR6
After some googling looks like I should be able to use a ratio / speedo correction box .
El XR6 Turbo
Aiming for 300 rwkw
Posted: Sun Jul 28, 2013 10:56 am
Gallery: 10 images
Ride: 96 XH/97 EL
Square wave
red, white, black - white is the output, goes to the inst cluster, then the ECU.
Posted: Sun Jul 28, 2013 10:58 am
Gallery: 8 images
Ride: EL XR6
Thanks mate
El XR6 Turbo
Aiming for 300 rwkw
Posted: Tue Jul 30, 2013 1:24 am
Gallery: 10 images
Ride: 96 XH/97 EL
search for 'square' in krytox's threads, some more info for reading.
It is currently Sun Oct 04, 2026 8:11 pm All times are UTC + 11 hours
